Question about LG Studioworks 520SI Monitor
My computer screen displaced from it's position some part of upper part of the screen is always black some content in sides ( lower left and lower right sections) did not seem when i run any thing in full screen. it can't be managed by keyboard mouse or other input device there are 4 button on screen to manage it i have tried once but it get disturbed more. what should i do.
5 Suggested Answers
  • 93 Answers
SOURCE: running as second screen, drivers WILL NOT download from cd
on your display settings ehere you genreally adjust your resoultion. if you have connected 2 monitors ,you can now sww 1,2 monitors there on the sampl screen. click on the other monitor and change the resolution.
Posted on Aug 06, 2009
  • 5 Answers
SOURCE: Forte Manager d oesn t work
Try uninstalling Forte manager and setting your display properties through windows
Posted on Jul 05, 2010
SOURCE: I have an LG Flatiron
Check if the screen saver is set to come on at 90 minutes, and the VGA cable, is tightly connected at both ends, if so, it might be a virus, check your virus detecting software,
Posted on Nov 03, 2010
budmrtn
  • 11361 Answers
SOURCE: I have an LG-1934S. The
To find out where the problem is, you will have to try this monitor with another PC or try another monitor with this PC first to narrow down the problem.
Please post back after what you find out so we can help you further.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jun 24, 2011
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
Black screen with blinking curser in upper left
how long did you wait? sometimes on first boot after recovery it take a few minutes. if you don't get any error messages i'd wait and see, if you wait for a long time and nothing happens reboot and try to do the recovery again.
Feb 11, 2012 | Acer Computers & Internet
Where is the sensor and what does it look like, that tells the computer to raise or lower the rear air suspension on my 2000 town car, I installed a monroe conversion kit to coil springs & shocks, The...
It is below the left rear(driver) side of the car, on the left upper control arm. It is probably a small box, with an arm attached to a near component to measure height and movement.
Jun 18, 2011 | 2000 Lincoln Town Car
P4b533 i dont remember how i make a reset and power cinch on computer to mother board with cable
if your board screwed on its case already,
there is a 9 pin color black at lower right side of your board if your infront of it, in usual position. firs t(2) two in upper right is for the power switch, and the two pin behind it is for the reset switch. the two pin beside of power switch at left is for power LED/Light, behind that is for HDD LED.
spare the last pin left at lower right.
Mar 12, 2011 | ASUS P4B533-E (P4B533-E/L/1394)...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
How to set alarm clock
Press the lower button on the left side of the watch to enter the menu. Then press the alarm selection key (5). Use the 1 and AB keys to scroll through the existing alarms. Once on the desired alarm, press and hold the upper button on the left side until the left number on the hour starts to blink. Use the number pad to select the desired alarm time. You can scroll past unneeded number spots by pressing the lower button on the left side. When finished, press the upper left button again and you are good to go. A quick press of the upper left button will activate or deactivate the alarm. Make sure the black lines near the upper left button are visible to indicate the alarm will go off.
Dec 11, 2009 | Casio E-Databank EDB6101C Wrist Watch
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
LG Studioworks 520SI Monitor Logo
83 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
