Question about Nokia 3110 Cellular Phone
Nokia 3110 restiction code - Nokia 3110 Cellular Phone
  • 117 Answers
SOURCE: phone restiction code
resriction codes are best obtained from the original carrier. There are websites that cn get you an unlock code but they may cost $$. Be careful if you obtain a code from anyone besides the original carrier. If you enter the wrong unlock code too many times your phone will be permanently locked to the original carrier.
Posted on Feb 05, 2008
abhi2664
  • 3 Answers
SOURCE: master code for all nokia 3110
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#06# : Checking the IMEI (International Mobile Equipment Identity)
*#7780# Restores Factory Settings (Memory, language, counters are not included).
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#746025625# [*#sim0clock#]
Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#92702689# [*#war0anty#]
Press the following warranty code :
6232 (OK) : Displays the Month and Year of Manufacture (0997)
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove SIM card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key.
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Posted on Jun 10, 2008
  • 234 Answers
SOURCE: To unlock my nokia phone and get restiction code
Why are you asking other people for your restriction code? Only you can know this answer. If you forgot your code, you need to have the phone de-memorized and this will cause you to lose all memory of any stored info; you will also have to proove you are the owner of the phone. You will need to go to a phone center that services your carrier.
Posted on Nov 28, 2009
  • 186 Answers
SOURCE: nokia 3110 restiction code
Hi ,
Try the default code 12345 .If u have changed the code then any of the following method should work fine .
Method 1 : You can open ur lock with a master code . To get the master click here . You will have to enter your IMEI no and u can generate the master code.
Method 2 : please visit to the following website and get the master code . This website provides the master code at the cheapest rate and it is very reliable . You will get the master code within 2hrs maximum .Clickhere for the website . NOTE : Please don't try any other website as they may deceive you
Method 3 : If u are not ok with online business please take ur mobile to the nearest service station and get it unlocked as they have the required software and the flash cable .
For any quires write back to me .If yo are satisfied with my answer please vote for me(with at least 3ups) . thanks in advance
Posted on Nov 27, 2010
  • 1010 Answers
SOURCE: Can you please tell me
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
You can get the unlock code through online..........i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Posted on Nov 30, 2010
I need a restiction code for nokia c3 for free please help !!
If your mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. but at a free of cost is not possible for your mobile so do not worry about this one get the code at a reasonable cost itself..........
Restriction code for your nokia model mobile can be got at Prounlocking.com
which gives easy instructions to unlock your mobile.
Apr 05, 2012 | Nokia 3110 Cellular Phone
My phone want restiction code IMEI is 356029030204944
Jul 27, 2011 | Nokia 3110 Cellular Phone
My 3110c-showing phone restiction.imei no-359309023619788
Restriction code is nothing but the unlock code........unlocking your phone just removes the SIM card restriction on your phone so that you can use any other network's SIM card.
Get the restriction code for your Nokia 3110C model mobile, through this site http://www.theunlockspot.com/nokia-3110-classic/rs10wp9/ , it provides the best instructions and simple methods for getting the restriction code for your nokia mobile..........
Jul 15, 2011 | Nokia 3110 Cellular Phone
Can you please tell me the restiction code for this nokia mobile 3110? IMEI no.353203032405782 Whenever i switch on my phone with my sim card inserted it dissplays enter restriction code. So i need your...
Nov 30, 2010 | Nokia 3110 Cellular Phone
Hi ,
Nov 27, 2010 | Nokia 3110 Cellular Phone
Nokia3110c restiction code problem
To get the security code to unlock the cell phone from the current cell phone provider so you can use it with a different phone provider, Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then this WEB site it provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
Try this WEB site also - Unlock Free
http://www.unlock-free.com
Jul 10, 2010 | Nokia 3110 Cellular Phone
Nokia 3110C phone restricted - enter restriction code.. How I know the restriction code to unlock the phone?
hello
the code which you ask for to unlock your nokia phone 3110C is 12345 this code will work out the problem of restriction enter it on your phone then your phone will be free to your operation
Good luck and thanks for using fixya.
May 28, 2010 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
96 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
