Question about Zebra S4M Thermal Label Printer
Printer is paused alert ribbon out after scrolling out rolls of ribbon, any attempt to re-align ribbon failed so far. Which printing mode should I be? print jobs make attempt to print but goes back to same pause alert. Have tried both PRINT METHOD and THERMAL TRANSFER on the printer setting as no such options on the printer itself without success. pls advice asap. Thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 51 Answers
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
Posted on Jun 20, 2011
Adjusting Datamax i class
If the ribbon is moving right on the I-4208 so far that you aren't getting print on the left of your label, the typical solution is to make sure that your ribbon roll is pushed all the way in, as far as it will go (at the top center of the printer on the black hub where the ribbon and it's cardboard core slide on). Similarly, make sure that the used ribbon that is winding on to the Rewind Hub at the top front is also in (to the left) as far as it will go).
Jun 26, 2014 | Datamax DMX-I-4208 Label Printer
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
After each print the pause button will continue to blink and will not print another label. I have to manually open the print head, close it and press pause for it to print. I do not understand the...
The ribbon is the transfer rolls same thing.
But check if you have not activate the pause mode in your driver!
This is an option to have the printer pause after printing
Aug 04, 2011 | Zebra Z4M Printer
Card keeps jamming and ribbon breaks
Download the Fargo Diagnose Utility .
But Requires Windows 98, 2000, NT, XP, Me; 16MB of RAM (Recommended); SVGA Monitor (800x600 or higher is required); and at least one printer drivers installed.
If a card becomes jammed inside the printer, the LCD Display will indicate
approximately where it is jammed. At this point you can either try to correct the
problem and continue printing with the same card, or remove the card completely
and continue printing with a new card. Refer to the following steps for instructions
on doing either:
1. Leave the power ON, and open of the printer?s Top Covers.
2. Remove the ribbon and overlaminate as needed.
3. If you would like to try to correct the problem and continue printing with
the same card, do so by pressing the On/Cancel button to advance the card or
the Pause/Resume button to reverse the card. Use these buttons to help free the
card from its jam. Try not to move the card too far from where it was just
before the jam occurred. Once the jam is cleared, replace media, close the Top
Cover(s), and press the Pause/Resume button to resume printing.
4. If you would like to remove the jammed card completely, do so by using the
On/Cancel and Pause/Resume buttons to manually eject the card. Then,
replace media, close the Top Covers, and press the On/Cancel button. At this
point, the LCD Display will prompt you to either press the Pause/Resume
button or the On/Cancel button. Pressing the Pause/Resume button will cause
the printer to feed in a new card and reprint the job which originally jammed
along with all subsequent jobs still being sent. Pressing the On/Cancel button
will reboot the printer and cancel all jobs within the printer?s memory. In this
case, you must also cancel and resend the print jobs from your computer.
CLEARING A RIBBON OR OVERLAMINATE JAM
If the ribbon or overlaminate becomes stuck to a card or jammed inside the printer,
the LCD Display will indicate that it is jammed. Refer to the following steps to clear
the jam:
1. Leave the power ON, and open the printer?s Top Covers as necessary.
2. Remove the Take-Up core (the side with used ribbon or overlaminate on it)
from in between the two black Drive Hubs.
3. Steadily pull the ribbon or overlaminate free from where it is jammed. If stuck
to a card, pull the ribbon or overlaminate off the card and throw the card away.
If it is jammed underneath the rollers, press and hold down the printer?s
Pause/Resume button as you gently pull up on the ribbon or overlaminate. Do
not **** the ribbon or overlaminate to free it, since this will increase the chance
of breaking it. If it does happen to break, simply tape the broken end of the
supply roll directly onto the take-up roll. Then, wind a few inches worth of
ribbon or overlaminate from the supply roll onto the take-up roll. Be sure the
ribbon or overlaminate is passing beneath both the supply and take-up rolls.
4. Once the jam is cleared, replace media, close the Top Covers, and press the
On/Cancel button. At this point, the LCD Display will prompt you to either
press the Pause/Resume button or the On/Cancel button. Pressing the
Pause/Resume button will cause the printer to feed in a new card and reprint
the job which originally jammed along with all subsequent jobs still being sent.
Pressing the On/Cancel button will reboot the printer and cancel all jobs
within the printer?s memory. In this case, you must also cancel and resend the
H. CLEANING THE CARD FEED ROLLERS
To assure consistent printer operation, all of the gray card feed rollers within the
printer should be cleaned during every ribbon change (every 250 prints) or if the
rollers are noticeably dirty. To clean these rollers, use the special adhesive-backed
Cleaning Cards from the Printer Cleaning Kit. Refer to the following steps to run a
Cleaning Card through your printer:
1. Open the Top Covers and remove all print supplies from the printer. Leave the
printer power ON and the Top Covers open throughout this procedure. The
Cleaning Roller Assembly can also remain within the printer during this
cleaning process.
2. Remove the Cleaning Card?s adhesive backing paper.
Nov 12, 2010 | Fargo Pro L ID Thermal Printer
Card jams and ribbon keeps breaking
CLEANING THE INSIDE OF THE PRINTER
As you use your printer, dust and other foreign particles may accumulate inside
the printer?s case. These particles are attracted to the underside of the ribbon by
static produced during printing and can cause voids on the printed image.
Periodically, use the following procedure to remove dust and other foreign
particles:
1. Open the printer?s Top Covers.
2. Remove the ribbon and overlaminate from the printer.
3. Use a Cleaning Pad from the Printer Cleaning Kit or a soft, lint-free cloth
slightly moistened with isopropyl alcohol to wipe out all visible areas inside
the printer. Remove any debris that may be inside. Be extremely careful not to
let any alcohol drip inside the printer!
4. Once the cleaned areas are completely dry and free of foreign debris, re-install
the ribbon and overlaminate, and close the covers.
F. CLEARING A CARD JAM
on doing either:
Section 7: Maintenance 53
Pro-L Card Printer User?s Manual
G. CLEARING A RIBBON OR OVERLAMINATE JAM
the jam:
cleaning process.
Printer is paused alert ribbon out, but we don't use a ribbon
Sounds like you're just in the wrong printing mode. Go into your front panel setup and search until you see
PRINT METHOD:
THERMAL TRANSFER.
Press the arrow buttons until it says DIRECT THERMAL, then save and exit.
Apr 05, 2010 | Zebra S4M Thermal Label Printer
HI,when I print , the printer do some label , after go in pause mode automatically message=" = continue = reprint" but after 1o label , the printer give a second error "out of ribbon" .Can you help me...
Hello
After many efforts I have found that in the new PX6i models, the "transfer ribbon mechanism" (the wheel that is responsible for making the ribbon roll) appears to be defective. What happens is that when rolling back in order to keep the ribbon stretched, instead of stopping at the fixed point, it continues to roll back a bit. After a few prints, this causes an "out of ribbon" error.
The solution: replace this part with a VALID part (a new one).
Pavel
Feb 08, 2010 | Intermec EasyCoder PX6i Thermal Label...
Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Mar 19, 2009 | Toshiba TEC B-572 Printer
How to reset factory default S4M. I try Pause and feed at starting the printer but it does'nt works. I have a display message: ALERT RIBON OUT.
This may be related to the printing mode you have configured. If you're printing on a thermal paper (direct) and the printer is configured for thermal transfer the printer will notify you that you are out of ribbon.
If you are printing on a regular paper and using a ribbon (thermal transfer) and the printer is configured for direct printing, the printer will notify you that you have a ribbon when you don't need one.
I hope this helps.
Regards,
Fábio
Jan 13, 2009 | Zebra S4M Thermal Label Printer
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Zebra S4M Thermal Label Printer Logo
416 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
