Question about Kicker ZR600 Car Audio Amplifier
Do i havde to have thed module hookec up in order for the amp to turn on?
  • 111 Answers
U have to have the positive wire running from battery to amp and the neg off the amp grounded to metal in the trunk then u most have the remote wire running from the back off the deck to the amp if it does not power the amp and u ran the (+) (-) the right way then that means u did not connect the remote wire which is blue to the right wire in the back of the deck when u do that the amp will turn on. the remote wire is for when u turn ur car off the radio shuts off with it but it has to be connected to the right wire on the back of the deck in order for the AMP to power up.
Posted on May 18, 2011
No pad sound
Not sure what module you're using this with, but I'm familiar with Roland electronic drum pads and modules, and guess the following would stand true for any pad / module combo....
I would check the following:
  1. Is the cable correctly connected at the pad?
  2. Is the cable correctly connected at the module?
  3. Is the module sound turned up?
  4. Are your headphones / speakers turned on & up
    (do other pads sound)?
  5. Is the fader for the specific pad (or pad group) turned up?
    (On a Roland module, where the pad is AUX1 to 4 - the 'fader' button needs to be pressed in order to operate the AUX slider).
    The next couple of things are less likely, but possible.
  6. Does the pad have a polarity switch on? - try switching it.
  7. Has he correct pad type been assigned in the module?
  8. Has an instrument been assigned to the pad
    (Roland: Press INSTRUMENT, hit the Pad, select a sound)
If you get no joy with this - please drop me a message.
Dec 30, 2012 | Alesis e Practice Pad Electronic Drum...
1994 Buick Le Sabre Clock light wont turn off even when the car is off
Disconnect the battery from car terminals, wait for 10 minutes, and reconnect back the battery, in order to reset the electronic control module.
If this procedure will not help you need to access the electronic control module using suitable diagnostic equipment connected to the data link connector of the car, in order to pull out all DTC's memored. DTC = Diagnostic Trouble Code. Then you will bu full informed about the root cause of the problem, and you will be able to repair & replace bad pieces and reset the electronic control module.
Aug 02, 2011 | 1994 Buick LeSabre
I havde lost the buttom u press to move the handle up and down. where do i get another?
If you are within the UK, call 01234 344230 to order parts. This is the Uk distributor.
Hope this helps.
Jul 23, 2011 | Mountain Buggy Urban Single Stroller
We get power module failure signal. however, when we check the status of that power modules , it say off and ok. what does it mean????
You may have a bad power module somewhere in that unit but not that one... and you will need to turn it on -- rotate the chrome knob on the right of the power module in order to turn it on. It should say 'ON AND OK' or 'ON, FAULT'.
Let me know what happens.
If you need UPS, Surge, or Power Related help contact:
Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click YES :) ••
Apr 06, 2011 | APC Symmetra PX Power Module
We have a philips 42" HD TV. We havde a blue ray
theres extra speakers computer speakers you can hook up to port for louder sound.
Feb 17, 2011 | Philips GOGEAR SA6045 MP3 Player
I lost my driver cd i can 't download it 's configurayion
Log on to support.epson.com to get the drivers for your scanner.
Here is the link:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14549&prodoid=54582&infoType=Downloads&platform=Windows&BV_UseBVCookie=yes
Just choose which driver is compatible with your operating system.
May 19, 2009 | Epson Perfection 1240U Flatbed Scanner
Phone won't turn on no matter what I do.
disassemble yr phone, hold 4 10 mins and reassemble it.... If it dusnt work den the impulse hav havd damagd sum of d internal ports and pins...consult yr service centre r sum reliable repairin centre..
Apr 12, 2009 | Lands Phones
Kicker ZR600 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
