Question about Lexmark C510 Laser Printer
Transfer roller missing fault 2-93 - Lexmark C510 Laser Printer
    Genius:
  • 1,087 Answers
Please click on the link below to resolve this type of error.
http://bitly.com/ouUZ2k
If you need further assistance please contact Lexmark Technical Support.
Posted on Jul 26, 2011
Schema of transfer roller
You will need to replace the transfer roller if it's broken. Please call our Technical Support Hotline for further assistance. Alternatively, you can contact any of our Authorized Service Partners by clicking on the link below.
Link for Authorized Service Partners: http://bit.ly/UeQhSB
Jul 06, 2012 | Lexmark C510 Laser Printer
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
Have error code 917.0 on Lexmark 640 laser printer.
From the service manual:
917 .00 Problem with transfer - transfer servo start error.
• Check HVPS
• Check system board
• Check HVPS/input sensor/toner sensor cable.
Often the problem is caused by the transfer roller (foam roller underneath the toner) not seated correctly (the gear should be at the right side of the printer).
Less often the charge roller is missing (the roller that comes down when you close the front door).
Dec 28, 2010 | Lexmark Office Equipment & Supplies
What does this error message mean: "917.00 service transfer roll"
The transfer roller is missing, not touching the drum, poor contact to the transfer high voltage or transfer high voltage shorted.
The trasfer roller is below the drum. Its bearings are on springs to press the paper against the drum. The drum rotates it by gears at one end. One of the bearings have electrical contact with the spring and the spring is connected to the DC controller. The transfer roller receives high voltage that attracts the toner from the drum. It's current is measured and when it's not within specifications the error occures.
Aug 05, 2010 | Dell 5210n Laser Printer
Need Help! What does the Error message "Set transfer roller" mean?
"Set transfer roller" means that the set transfer roller is missing or not installed properly. Install or reseat the transfer roller.
Mar 30, 2010 | Lexmark C500n Laser Printer
59.99 printer error on hp lj3500, reset as per suggestion as same fault. thanks
your second transfer roller is not engaging.check the transfer roller.(long dark gray roller inside the machine.
Jun 23, 2009 | HP Color LaserJet 3500 Printer
I think the transfer roller is damaged
Yes - it probably is the transfer roller. the P# is RG0-1025
Jun 09, 2008 | Canon PC-D320 Copier
Konica minolta magicolour 2530dl
open side door and there is a transfer roller / one big black roller on the cover/ try reinstall it, maybe its not installed correctly
May 14, 2008 | Konica Minolta magicolor 2300DL Laser...
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Fault code SC402
Transfer roller leak error 2
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
transfer roller is not detected.
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
incorrectly
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Nov 19, 2007 | Ricoh Aficio 180 Laser Printer
Lexmark C510 Laser Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
