Question about Nikon Super Coolscan 4000 ED Film Scanner (35 mm)
Have Nikon coolscan 4000 ED and connected to Win 7 via USB firewire IEEE 1394 (6 pin) cable. Nikon scan nor VueScan do not recognize there is a scanner? do you know what the problem could be? Is there any way to test the scanner? It look like there is a TWAIN installed.
  • 823 Answers
You need to install the drivers before the pc will recognize that there is a scanner connected to it. I would also suggest using the software that came with the scanner instead of just a program that you already have in your computer.
Here is a link to the users manual with the specs and software required to run the scanner correctly below. You can usually get a copy of just any software from CNET's website (www.cnet.com). Try locating the name of the software that the manual says came with your scanner and then go to CNET's website and find a trial version or free version and download then install it on your computer before connecting the scanner. You need to make sure that you do not connect the scanner before installing the drivers and/or software, so if you have it connected now remove the cable.
http://support.nikonusa.com/app/answers/detail/a_id/13227/~/super-coolscan-ls4000-ed-%2F-coolscan-iv-ed-user's-manual
Windows 7 does not run scanners the way that Windows Xp & Vista do. Your scanner may be set up correctly now before chasing down the driver and/or software. You might want to check using the method listed below before making any changes as noted above.
With XP, the scanners software would be installed on the pc before using and you would see a picture of the scanner with the name on your desktop. To scan you just double click the ICON and follow the prompts.
With Windows 7, to use your scanner you need to click on the round globe on the bottom left of your screen (the one with the flag in it) and then go to "devices and printers" and click on that too.
Find the name of your scanner and right click with your mouse on top of it to get a drop down list of choices. In that drop down list find "scan" and click on it and you will get a drop down list of choices with scanning preferences. Choose your preferences and click scan or "ok" at the bottom. Thats how you scan something in Windows 7. Maybe you were opening the software and trying to scan something that way? After the scanner scans your image, it will number it and take you to where it stores the default scans. If you double click on the document or picture in this area, it will open it in your default software. If you have your computer set to use Vue Soft, then double clicking on the picture or document after scanning it will open it in that software.
Hope this helps?
Posted on May 18, 2011
Recently upgraded from Windows Vista to Windows 7. Where can I get correct drivers to run with my Nikon Super Coolscan slide scanner LS-4000 ED model. I have Nikon Scan 3.0 twain software. Stu Milligan
Hello there.
This will help you if you have 64-bit Windows 7, because officially, there is not windows 7 64 bit driver.
Just read and do everything.
http://www.earthboundlight.com/phototips/coolscan-vista-64.html
Otherwise, if you have windows 7 32bit click here:
link
To check bits, go right click on My Computer, Properties, and you will see it.
Sincerely,
Steve TM
May 28, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon Coolscan 9000 ED can not be recognized by computer
I am having the exact same problem...cannot get the Coolscan 9000 to show up in Device Manager. One thing I did try (to no avail) was to run the regsweeper.exe file that comes with the Nikon scan disk. It clears your registry when you reinstall. It still did not work though so I have a lovely "shoebox" sitting next to my computer that is worthless!
Dec 08, 2008 | Office Equipment & Supplies
Nikon Coolscan 9000 not recognized by XP computer anymore....
I read and would like to thank, the person who mentioned this as a solution. It was stated that if you have more than one firewire on your computer, when you open the Nikon, both signals, or whatever happens in computerland, don't connect. Upon removing the drive in the other firewire, Nikon clicks in everytime. Answer: have only ONE active firewire at a time. You may need to unplug the cable to the scanner and reconnect. But that's it. I've not had any problems since
Jun 09, 2008 | Nikon CoolScan 9000 ED Film Scanner
USB cable from scanner to new Dell Optiplex 755
If you look carefully at the cable, you will notice it is a firewire cable (IEEE1394), not USB. You will need a firewire interface on your computer to use the Nikon scanner. It will not work with a USB port.
Jan 02, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Firewire. USB2
Either or is my understanding- the scanner will accept either. I can see no need for both.
Sep 01, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon Super Coolscan 4000 ED Film Scanner (35 mm) Logo
329 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
