Question about Cycling
I need a user manual for a jag electric scooter xp-03c so I can get new batteries and a throttle cable
  • mwkoski May 20, 2011
    This is the problem.It only says it is a Jag scooter.The only # i have is xp-o3c and I am not sure what this # is.
  • 823 Answers
You can find replacement parts for your scooter by clicking on the link below. They have a live help section and you can chat with them to give them your exact model information and they will tell you where you can purchase the parts that you need to repair your scooter.
http://www.electric-scooters-galore.com/jaguarxk.html
Posted on May 18, 2011
My Pulse Scout 49cc takes about 10 kicks to start in morning ok on electric start
Hi, Michael and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
10. Enricher valve inoperative.
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Hard starting scooter 49ccScoot com Scooter Forums
Troubleshooting Your Scooter
http://www.scooterunderground.com/knowledge/manuals/documents/JetEuro50_Service_manual.pdf
Tao Tao 50cc Scooter Won Start SOLVED REPLACE CARBURATOR
Nov 18, 2016 | Motorcycles
Has 2 new batteries, but I am now getting the small green lite flashing constantly. Throttle error? Won't hold a charge either.
Possible controller trip. You may be attempting to install the battery while the key is inserted or the motor controllermay be in overheat protective mode.
Shut down your scooter for a minimum of several minutes to allow the controller to cool. Or, try reinserting the key into the key switch.
download your user manual here and read troubleshootint 9
http://www.pridemobility.com/scooters/maxima.asp#tabs-6
May 31, 2015 | Pride Maxima 4-Wheel 4-Wheel Scooter
I have a Taotao electric scooter not a mobility scooter the scooter is fully charged the lights and horn work fine but when you turn the throttle nothing happens it makes a kind of clicking sound
Not familiar with your particular scooter - but I am well versed with electricity. The issue you're seeing is likely a result of a poor connection somewhere. The amount of power (current in amps) required to operate the horn or lights is a small fraction of that needed to run the motor.
You should trace larger sized wires/cables from the motor back as far as you can - ideally to the battery if possible. Remove, thoroughly clean and reconnect each of these cables under each terminal screw - one at a time. This way you'll know any unconnected cable goes on the only terminal that is removed.
At this point, you should have 100% good connections for all high current loads - including the motor and will probably be able to use the scooter. Placing the battery on a slow trickle charger overnight will help ensure that the battery is fully charged - not just enough to operate the horn or lights.
May 11, 2015 | Electric Health & Beauty
Please robin - try to understand - you tell me that the beeper is attached to the cable - i don't know where the cable is - don't tell me its by the controller - i don't know what the controller is or
the beeps are diagnostic beep codes and the sounder should not be disconnected,
count the number of beeps then refer to my chart.will tell you what problem is
2 battery voltage too low =fully charge min 8 hours
3 volts too high =contact dealer
5 scooter in freewheel or Brake trip=chech in drive then turn on
6 throttle wig wag faulty or not in center when turning key
7 throttle or speed pot wireing or faulty
8 motor faulty or wireing poor /disconnected
9 battery pack pads and terminals coroded .replace them £2 eachn from pride or controller faulty ..replace
Advisory the analog battery guages on these regulary go faulty and read over full get electrical friend to check battery volts 12.8 to 13volt =fully charged
Dec 29, 2014 | Pride Go-Go Sport 4-Wheel
My electric scooter hesitates, then goes, hesitates, then goes without letting up on the throttle
Going and Slowing is usually a problem with the throttle pot. They are often easy to fix yourself with a bit of WD40 once you have found out where the throttle pot is on your machine. Sometimes they have to be replaced, but fortunately the part is quite cheap. You didn't say what brand your scooter is, but Pride scooters are known for throttle pot problems.
Sep 16, 2014 | Electric Mobility Merits Electric...
I have two electric razor 175 and put new batteries in both of them. After fully charging them all i hear is a click everytime turn the throttle but nothing,, anyone that can help please help
Thank you for choosing FixYa, I will be helping you today :)
When using an electric scooter, it's always important to know that you must advance on the scooter manually, and during this action, only then can you turn the throttle. The engine on an electric scooter is not powerful enough to move a person by itself.
Hope this helps, thank you :)
Jul 03, 2011 | Razor E100 Electric Scooter
I have a 240W electric scooter with 12V X 4 batteries of 20AH each. The battery current meter, headlamp, trafficator lights, horn etc work. Throttle does not produce motor rotation.All connections checked....
Make sure that the manual brake release/freewheel lever is enaged as if it is not, this will allow you to push the scooter, but will not engage the drive motors. It is usually located on the rear of the vehicle; check your owner's manual.
If this does not work, contact the manufacturer for additional troubleshooting.
Oct 25, 2010 | Electric Health & Beauty
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Cycling Logo
143 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
