Question about Canon PIXMA iP3000 InkJet Photo Printer
The canon mx700 printer
The black ink ran out, and we refilled the same cartridge. when we put it back the light was still flickering and it doesn't want to do anything.It doesn't want to scan fax make copies, nothing.What is the problem?
IB4G2008
  • 3587 Answers
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
Posted on Feb 15, 2008
SOURCE: we had just refilled the ink cartridge for canon ip1980
please reset manual first by pushing power button before plug in AC cord, then push resume button twice and release both, if still happen please reinstall driver
Posted on Mar 13, 2009
SOURCE: MX700 Will not scan with an empty ink cartidge?!
I just came up with the same problem. But if you keep pressing the right most button (the red one) for 5 seconds the message "replace ink cartridge" disappears and then you can use it as a scanner.
Posted on Mar 22, 2009
cropp
  • 377 Answers
SOURCE: Can not clear memory on PIXMA Canon MX700
dear david
try this
) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release
the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons.
(Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green,
starting with Alarm LED.)
4) When the Power LED lights in green (and "Service Mode Idle" is displayed on the LCD), press the Stop/Reset button 4 times.
5) Press ON/OFF, press Stop/Reset 2 times
6) Press ON/OFF. Unplug printer and plug back in. turn on and should be cleared
oke , post me back
cropp
Posted on Apr 10, 2009
  • 85 Answers
SOURCE: canon MX700 cannot detect remaining ink level
Try to run the reset tool for canon printers which will reset the printer.
http://www.ziddu.com/download/2620692/IPtools.zip.html
Posted on Jul 27, 2009
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
How to refill pixma mx700 magenta ink tank without
The colors are individual. That machine takes the Canon CLI-8. I would suggest reading your manual on what the procedure is for changing the ink cartridges out, it typically varies slightly by machine. There should be an option somewhere one of the menus to change the ink cartridges. When you buy a replacement be sure you buy from someone who isn't trying to scam you. I would recommend Cartridge World, of course, or OEM. Do not use cheap online cartridges, you will only have headache later.
Feb 15, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Can I use only black ink cartridge with the MX700? All other colors removed?
Canon printers won't let you do that, all colors have to be installed and not empty, for it to do anything. If you ran with colors removed the printhead would dry and plug and require replacement.
Nov 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Magenta ran out, can't print in black
Sorry! the printer is so designed to do an ink and cartridge check and if one is mt so be it no print!
Aug 01, 2009 | Office Equipment & Supplies
New Canon ink tank not recognized.
Check that the cartridge chip is not soiled or damaged in any way... Give it a quick clean, check that there's no ink anywhere else on the cartridge as there are sensor points that an LED uses to check the cartridge ink levels too.
If none of that works, phone Canon and request a replacement as some cartridges are known to have faulty chips.
Jan 29, 2009 | Canon MX700 Office All-In-One InkJet...
Refilled Ink cartridge but the printer says there is no Ink
you refilled or purchased a new cartridge? If you refilled ; did you do it after the printer told you it was out? The cartridge electricial would have to be reset. How to do that is a guarded secret for Canon. Buy a Canon One and replace Cartridge, would one on solution.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=14991
Jan 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The red lights on the ink thing wont turn on
Dear Titis,
Are you using genuine canon cartridges or are the cartridges you are trying to install refill or non genuine?
Gremlin 11
Dec 10, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon MP180
There is no way to reset the ink levels on the new canon cartridges. you need to turn off the ink status monitor :(
You'll know it's time to refill again when your printing starts to fade, streak, or discolor.
Aug 24, 2008 | Canon MP610 Photo All-In-One Printer
Will PGI-5BK and BCI-3E ink tanks fit in the MX700?
Ink Tanks:
PGI-5BK, CLI-8C/CLI-8M/CLI-8Y
According to the canon australia website these are the inks for the MX700
Feb 20, 2008 | Canon MX700 Office All-In-One InkJet...
got backup?
Feb 15, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
29 people viewed this question
old marine
old marine
