Question about Briggs & Stratton Garden
I have a JD 3300 psi 1150 Briggs n Stratton pw. It is leaking from the oil cap/ dipstick seemingly from high pressure. The cap dipstick is about 10 inches long, so this is a real squirt goin on. There is no rubber oring or gasket in the cap. I bought it from a pawn shop new, or at least seemed new as the hose and tips were still factory wrapped. Any ideas?
    Guru:
  • 302 Answers
Either there is compression from cylinder getting into crankcase pushing the oil out or the oil level is too high.
Posted on May 19, 2011
Why is oil leaking from air cleaner?
this is usually due to an oil overfill situation. You most likely added the full quart of oil into the crankcase on setting it up without checking the actual oil level periodically as you fill it. Recheck and drain out the excess as needed.
Jul 14, 2014 | Briggs & Stratton 020324 3700 PSI Pro...
6.5 briggs and stratton leaking motor oil through the filter area
How does it run? Is it back firing through the air filter box area? And although your stating it is oil is it actually oil or gasoline that is black due to getting dirty? Don't shoot me! I'm going on what information I'm reading what you submitted. If oil is it enough to show up quickly on the dipstick/engine oil level ? Get back to us and we can go further.
Nov 23, 2013 | Briggs & Stratton 491056 492932 Briggs ...
I have the John Deer 3800 psi from lowes. The machine is in great running order it just seems to be losing psi as I use it. Also checking the oil in the Honda 13hp motor and in the pump. Do you take the...
Thread the dip stip back in to get a true reading of the oil level. Either oil filler may be used to top off the crank case. There is only one crank case - the oil on one side is the same oil seen in the other filler.
Apr 12, 2011 | Briggs & Stratton Garden
When adding SAE 30 oil to new pw, do we add to the pump reservoir only or do we also add to the two oil inlets on either side of the engine housing?
From what i've read in the manual you need to fill both the pump and the motor. The pump itself will have a dipstick, the motor gets filled to the top. If the motor has two inlets one should fill up when you pour in the other side. Most briggs had two motor oil inlets so the motor could be used on several types of equipment. The pump itself should use about 9.6 oz
Mar 03, 2011 | Briggs & Stratton Prosumer 2800 PSI (Gas -...
I have a white mower with a 18 hp intek v-twin briggs & stratton motor. I was cutting the lawn and it loss power all of the sudden, then it died. Now it won't start. I changed the plugs, which looked...
back pressure is from a blocked muffler ( carbon build up)
if it is that old then it could be overheating from grass and dirt build up around the cylinder fins and not cooling properly
Apr 06, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
May 23, 2010 | Briggs & Stratton Briggs Stratton 2000...
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
148 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
