Question about Xerox Phaser 6110 Laser Printer
How to reset Phaser 6110 imaging unit. - Xerox Phaser 6110 Laser Printer
  • 304 Answers
No reset for imaging unit, only when you change it(autoreset).
You can reset Fuser and Transfer Roller this way:
To reset the fuser and transfer roller life usage from the printers control panel:
a. From the main menu select, Menu-Setup --> Maintenance --> Check other.
b. Select the appropriate part name from the list by using the Up Scroll and Down Scroll buttons
c. Select Reset.
Posted on Jul 11, 2011
  • guilopmar Jul 11, 2011
    Sorry, that solution for Xerox Phaser 6100.
    Try this
    * How to initialize a the value of part's life span:
    From the control panel, select the following items in order:
    Menu-Setup - Maintenance - Check other - (Select a desired part) - Reset
4 Suggested Answers
  • 340 Answers
SOURCE: Dear support hi! I need
Solution : Replace the Imaging Unit The life of the Imaging Unit is approximately 20,000 pages for black and white, or 12,500 pages for color. When the life span of the Imaging Unit has expired, the Smart Panel program window will be displayed on the computer, indicating the unit needs to be replaced; otherwise, your printer will stop printing.
WARNING: Some parts inside the printer may be hot when the printer is powered ON, or after printing. Be careful not to burn yourself when working inside the printer.
To replace the Imaging Unit:
  1. Power OFF the printer. Press the power switch on the back of the printer to the OFF position (O).
  2. Wait for the printer to cool.
  3. Open the Front Cover.
  4. Remove all of the Toner (Dry Ink) Cartridges and the Waste Toner Container from the printer. See the Related Items below for additional information.
  5. Pull the Imaging Unit out of the printer using the handle on the bottom of the unit.
  6. Extend the top handle on the Imaging Unit and then grasp the handle to pull the unit completely out of the printer.
    CAUTION: Do not use sharp objects, such as a knife or scissors, to open the Imaging Unit package as this could damage the surface of the unit. Be careful not to scratch the surface of the unit.
    Do not expose the Imaging Unit to light for more than a few minutes. Cover it with a piece of paper to protect it, if necessary.
  7. Remove the new Imaging Unit from its package. Remove the protective devices on both sides of the unit and the paper protecting the surface of the unit.
  8. Holding the handles on the new Imaging Unit, insert and push the unit into the printer until it clicks into position.
  9. Remove the four dummy caps on the Toner Cartridge entrances of the Imaging Unit.
  10. Re-install the Toner Cartridges and the Waste Toner Container into their corresponding slots until they click into position.
  11. Close the Front Cover and make sure it is securely latched. If the cover is not completely closed, the printer will not operate.
  12. Power ON the printer. Press the power switch to the ON position (').
    NOTE: Each LED on the Control Panel blinks red in a repeated order. Wait for about three minutes for the printer to reach a 'Ready' status.
    NOTE: If there is a cracking sound, re-install the Imaging Unit.
Click on the [Recycling] link under the Product Resources menu on this window.
Posted on Oct 30, 2010
ginko
  • 19396 Answers
SOURCE: dear brother, how do I
Hi.
There is no software that you just use and reset chip. Software discussed in forums like this is generic HEX (machine language) editor used with home built serial interface.
The best solution is getting a chip like this.
Here also the repair manual: Phaser 6110 MFP Service Documentation
Regards.
Ginko.
Posted on Feb 22, 2011
faxman789
  • 297 Answers
SOURCE: Program to reset unit imaging xerox phaser 6110 please
Image units can't be reset by software. There is a chip that needs to be replaced on the cartridge if you refill it with new toner. It should be available from the same place you got the toner. (I assume you refilled it and it still says it is out of toner)
Posted on Dec 09, 2011
Xerox 6110
Fixya does not have firmware. Search Xerox's site for the update.
May 15, 2014 | Office Equipment & Supplies
Dec 01, 2011 | Xerox Phaser 6110 Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Please, send me the firmware for Xerox 6110 MFP for reset Image Unit;
firmware to have changed only very extreme case!!! no to reset image unit
Dec 07, 2010 | Xerox Phaser 6110 Laser Printer
Can I empty my Xerox 6110 waste toner container and put it back in again, or will it wreck my machine? What's the best way to do it?
You sure can, until my piece of sh*t 6110 sied yesterday I emptied it weekly (that's for 2 years). It wasn't that that killed it, the imaging unit went.
May 01, 2010 | Xerox Phaser 6110MFP All-In-One Laser...
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
Is it possible to reset xerox phaser 6110mfp imaging units
The image unit can be reset.
This is done by use of a small program that Xerox certified engineers use. The process is really simple and only takes about 30 secs, if you have access to the program ( I do... :) ) It can also be used to reset transfer belt life etc ....
Mar 02, 2010 | Xerox Phaser 6110 Laser Printer
I have not used my Phaser 6110 for about 3 months, and now print quality is bad. It appears to be only the black that is affected. print quality is faint although slightly darker down one side. I have...
This sounds like the doctor blade within the black developer unit inside the image unit has become contaminated. This means that not enough black toner will be attracted to the developer roller. This usually manifests itself as feint thin lines of print running vertically through the text being printed. This can be repaired and is a known issue with this image unit.
If the printer is in warranty tell them you want it replaced, if not then take the image unit back to the supplier you bought it from and demand a replacement.
Nov 24, 2009 | Xerox Phaser 6110 Laser Printer
Xerox Phaser  6110 Laser Printer Logo
2,133 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
