Question about Kyocera Mita KM-4035 Printer
Always add toner - Kyocera Mita KM-4035 Printer
  • Kyocera Mita Master
  • 32,281 Answers
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Posted on May 18, 2011
Add toner problem
toner is empty replace new toner
Jul 14, 2014 | Ricoh Aficio Mp2500 Mp2000 Mp1600 3030...
Add toner always show copy not print and ready
When the toner supply belt is broken or displace than toner not supply from the cartridge in the DV unit.You shuld check this drive section and replace new one.I wish best luck.
Oct 26, 2013 | Kyocera Mita KM-4035 Printer
Add toner always
my dear your problem toner feed solonide clean or change solnide
Add toner always
Could be a lot of things. start with toner hopper is bottle turning is end cap in toner bottle being pull out when toner handle is lower is side door open and dose toner fall out when bottle is turning. then next is developer powder how many copies on it. might be time to replace powder. or could be gears broken on developer unit. I would say if you not mechanical incline call tech.
Oct 08, 2011 | Ricoh Aficio 2035 Copier
Kyocera km 4035 always add toner
It sounds like you may have a bad toner.
May 20, 2011 | Kyocera Mita KM-4035 Printer
Copier turns on and doesn't stop running. Can't print or reset. It seams stuck in warmup.
This almost always means the toner cartridge is empty. This is especially true if you can hear sort of a thump noise about every 5 seconds or so. When these toner cartridges run out the machine will still try to add toner. If it does not get it, it will eventually shut down and turn on the red toner light which looks like a stack of 6 dots. Just turn the machine on and let it run. After a few minutes it will shut down and turn on the toner light. If not reply back.
Good Luck and Thank You for using Fixya.
Oct 17, 2010 | Sharp AL-1642CS Copier
I have 2 problem for Aficio 3045 i) the copier alway show toner sign on when i fill the toner or change the developer also the same. ii) B5 paper cannot be use,always jam when i using drawer or multiple...
most of this add toner problem came from the toner hopper, this need to be checked by a technician to fix the four plastic mylars to see to it that they are attached and properly scrapped the toner. next is the B4 fist do you set or is the right paper size is set on the drawers? what is the jam code so we can see if were is the fault of the machine?
Sep 09, 2010 | Ricoh Office Equipment & Supplies
How do I install the toner cartridge?
I reproduce below the content from Ricoh official website. The instructions to install toner cartridge are as follows:
Note: You can make about 50 copies even after the char_ric09.gif Add Toner indicator begins flashing, but replace toner early to prevent poor copy quality.
Please read the following warnings and notes before attempting to add toner.
WARNING
  • Do not incinerate used toner or toner containers. Tonerdust might ignite when exposed to an open flame. Dispose of used tonercontainers in accordance with local regulations.
  • Keep toner (used or unused) and toner containers out of reach of children.
  • Iftoner or used toner is inhaled, gargle with plenty of water and moveinto a fresh air environment. Consult a doctor if necessary.
  • If toner or used toner gets into your eyes, flush immediately with large amounts of water. Consult a doctor if necessary.
  • If toner or used toner is swallowed, dilute by drinking a large amount of water. Consult a doctor if necessary.
  • Avoidgetting toner on your clothes or skin when removing a paper jam orreplacing toner. If your skin comes into contact with toner, wash theaffected area thoroughly with soap and water.
  • Iftoner gets on your clothing, wash with cold water. Hot water will setthe toner into the fabric and may make removing the stain impossible.
To replace the toner, follow these steps:
  1. Keep the device switched on and only add toner when "Toner is Almost Empty" is displayed
  2. Open the Front Cover
  3. Lift the large green handle up to its full extent
  4. Press and hold down the green lever to the left of the green handle
  5. Use the green handle to pull out the Toner Tray slightly then release the green lever
  6. Pull out the Toner Tray to its full extent
  7. Push the neck of the Toner Bottle back towards the device until you can see the top of the bottle
  8. Lift out the Toner Bottle by the neck - being careful not to scatter loose toner
  9. Dispose of the Toner Bottle in accordance with your local environmental instructions
  10. Obtain a new Toner Bottle and shake it gently from side to side at least 5 times
  11. Remove and discard the black cap and place the Toner Bottle in the tray with the neck towards you
  12. Push the neck back into the black housing of the tray
  13. Push the whole assembly back into the device until it clicks into place
  14. Push the green handle down fully and close the Front Cover
  15. The device will perform a few seconds of internal checks before it is ready for use again
Important:
  • Fault may occur if you use toner other than the recommended type.
  • When adding toner, do not turn off the operation switch. If you do, settings will be lost.
  • Always add toner when the device instructs you.
  • When a message "Add toner." is shown on the display panel, replace the toner.
  • Store the toner bottles in a cool, dry place free from direct sunlight.
  • Store on a flat surface.
  • Do not repeatedly install and remove toner bottles. This will result in toner leakage.
  • Do not shake the removed toner bottle. Remaining toner might scatter.
Aug 17, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
The add toner light stays on with a new toner cartridge
Yes, the machine will only make single copies if the toner light is on. Was the toner cart genuine Copystar? Or perhaps Kyocera cart? The machine is made by Kyocera and marketed under both name brands, however, the toner carts are different for both machines. I have seen many times that aftermarket carts will not always work properly.
Jan 06, 2009 | Copystar CS-1510 Copier
Kyocera Mita KM-4035 Printer Logo
108 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
