Question about Samsung HT-TQ25 Theater System
Samsung HT-TQ25... did firmware update, now the machine will not do anything... Unable to reflash as it will no longer read the DVD or USB ports. Device powers on, and buttons work, but will not play or load from any slot / port
SOURCE: RE: Problem with SAMSUNG DVD-R135
I have tried several brands of dvd-r's. Less than a handful work. I cleaned the lens which did not solve the problem, however, I stumbled upon a fix (sort of). I normally (as we all do) put in the dvd-r when the power is on and get the dreaded "the disc cannot be played" and then the machine spits out the disc. After cleaning, I had left the disc in and unplugged the machine just to look around in there some more, when I plugged it back in and powered on it worked!?!? So I tried it several more times... (1) put disc in, (2) turn power off BEFORE it can give you the error, (3) wait for spindown then power on. All those Frisbees work when I do this. All those discs I thought were coasters work using this method, go figure. Any thoughts?
Posted on Apr 29, 2008
  • 3 Answers
SOURCE: samsung ht-x20 unlock codes
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problem. Swapnil
Posted on Nov 04, 2008
ginko
  • 19396 Answers
SOURCE: Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray: Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
Posted on Feb 10, 2009
ginko
  • 19396 Answers
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
chipsandnuts
  • 70 Answers
SOURCE: display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Posted on Jul 03, 2009
DAV-DZ777 no longer plays TV sound through home theatre. DVD, radio etc still works...
The hdmi needs to be ARC compatible and connected to the HDMI connected labled Arc.
Sep 10, 2016 | Sony Home Theater: DAV-DZ777 CODE FREE...
Samsung ht-c6930w
Latest firmware is..
HTB-C6930WWB-1016.2.zip
This can be downloaded (with instructions) at http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SIA00201&prd_ia_cd=802&prd_mdl_cd=HT-C6930W%2FXEU&prd_mdl_name=HT-C6930W%2FXEU&srchword=HT-C6930+3D+Blu-ray+5.1+Home+Entertainment+System
If you already have this firmware then you need to contact Samsung.. The last upgrade was 5th oct 2012.. not good enough Samsung.. :(
Dec 02, 2013 | Televison & Video
HT-RC360 no longer feeds video to my TV .
Update firmware (usually every 6 months). Connect the ethernet to the unit, press Net and Power button simultaneously. Hit Enter as directed. Takes up to 60 minutes. OR (if no internet service), download firmware updates onto a USB (32MB) and connect it to the USB port. If you do not update voluntarily, unit will suddenly not feed video.
Aug 26, 2012 | Onkyo Ht-rc360 7.2ch Network Audio/video...
Que drive no longer recognized
verify that the USB port is working, you may also try it on another machine to see if it works, you may have a corrupt driver for your usb port. If it works on another machine then uninstall and reinstall updated drivers for your usb ports. I hope this helps, Good luck.
Sep 23, 2009 | QPS Que! USB 2.0 Drive CD-RW Burner
SONY HT DAV-DZ270
Hi all!!!
I am looking to play movies through USB in Sony DAV-DZ270 without looking to buy or upgrade to any other Home theater system. Is there any firmware or software update to play movies through USB? Or can the Sony people fix my requierment?
May 26, 2009 | Sony Televison & Video
Samsung HT-TX72 Home theater system - Disk Error
Try updating your firmware... samsung.com Or have you tried that?
Dec 05, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Playing an iPod
thers firmware update i bet for it u may be able to update yourself witth thumb drive in that usb port in front that should help it from samsung.com website x50 ok
Jun 20, 2007 | Samsung HT-X50 System
Samsung HT-TQ25 Theater System Logo
226 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
