I cant get the cable to work i have it connected to the cable out let but what input do i put it on
  • 111 Answers
Component if running off a cable box channel 3 if running off a cable box with out the red blue and green wire
Posted on May 18, 2011
Why cant i get my cable wire to work on the tv
If you have been using the antennae input and you connect the cable to the cable in connection, you have to change the TV input to the cable input. Won't work otherwise.
Maybe you have a panel with controls where you can hit the MENU button and select the other input.
Feb 11, 2015 | Toshiba Televison & Video
I have a 19 or 20 in rca truflat and cant figure how to make my dvd work. i have the cables in line out on the dvd and line in on the tv. is there a way to change the input, ican not seem to find a way.
should be on the remote should says Input or Source
look at where you plug in the devices, should say Video 1, 2 ,3
Then use remote to put on the right input sources.
Also make sure you have the RCA cable connected properly, not all cables works some can be broken, make sure they are new.
good luck
Apr 13, 2011 | RCA TruFlat 27F520T 27" TV
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
Just brought aamsung home theatre and cant get tv channels to play through it
the LG has optical audio out put. If the samsung has the same optical input,then use an optical toslink cable to connect and select that input. Other wise Gefen(co) makes optical to analog adaptors available on ebay. You may also be able to run the audio out of you sat reciever or cable box directly to the "aux" inputs of your samsung via reg rca stlye cables and select that input!
Jun 04, 2010 | LG 42LG50 42 in. LCD HDTV
Cable to tv cant find tvs cable port
fisrtly check for a rf connection on your tv. if you cant find it buy a converter rf to a/v, this will help you to input your cable and have a/v out put which you can connect to your tv.
Jan 04, 2010 | Akai LCT3201TD 32 in. LCD Television
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Cant set up anyhting to my cable box/ dvdr /tv
buy a new rca cable or RF cable for you're cable box ,then connect the output of dvd red/white/yellow to the tv video input red/white/ yellow and for you're cable box connect the RF cable to tv ant.
Mar 23, 2008 | Cyberhome DVR 1600 DVD Recorder
Hi i cant get no sound other than frying inmt rear left and right spearkerall the other is working
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Nov 03, 2007 | Audio Players & Recorders
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
