Question about Kenmore 75180 Wall/Window Air Conditioner
Does the Kenmore model 75180 run on 220 volt or 110 ??
    Brigadier General:
  • 4,736 Answers
Chuck, your particular model (which has been discontinued) had two different models with 115 volt (110 is no longer around) and 250 volt.The rating should be on the manufacturer's serial data plate. Also, you may be able to tell by the power cord that was furnished with the unit.
I have included a link to you Owners/Installation Manual, which will provide more information on how to determine what voltage rating your specific unit has.
http://www.managemylife.com/mmh/owner_manuals/23524/KENMORE-Air-Conditioner-Room-%2842%29-LR707330?brand_name_search=58075180700+KENMORE
Hope this helped you. Please let me know. Thanks.
Posted on May 18, 2011
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
Modifying Power Supply for 220 to 110
If you cannot get a ECU board from HP to replace the 220 volt model.
Then
The easiest solution, use a stepdown transformer fro 22m to 110 volts. Make sure the stepdown ransformer has a power rating that can supply enought watts to run the printer.
Mar 25, 2012 | HP LaserJet 1300 Printer
Can you convert a 220 sears kenmore 700(*mauve) dryer to a 120v this a ol "70's" dryer
Not really, the rewiriing and electrical values would not work. A 110 volt burner is different from a 220 volt burner...the motor already runs on 110...
Feb 23, 2011 | Kenmore 700 6972 Dryer
I have a radial arm saw model 113.19790 I have no manual, I can't tell if it is 220 or 110 volts. It runs slow, can you tell me if this model is 220 or 110 volts. Thank You,,,, Denny
Craftsman Radial Arm Saw, model # 113.19790 requires 220 Vac. I purchased my saw brand new and I have yet to have a problem with it beyond typical alignments. My only complaint is with the 5/8" arbor.
Aug 16, 2010 | Craftsman Saws
Is kenmore 98702 220?? or 110???
if it has a small 3 prong plug then it's 110v for the washer but the dryer should be factory 220 volt however many were sold wired too! 110 volt! just look at the plug small plug 110v large 3 prong! 220v
Jan 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer model#110/62622100 will not atsrt
check to make sure you dont have a blown fuse or a triped breaker if they are fine if you have a volt meter take the back panel off on the control are or if it is the other kind losen up the two screws in the back of the control area and when you get it lifted up make sure unpluged then put the volt meter on the beep mode when probes touch then put it on the two spots on the swicth and push the button if it beeps it is good if it dont it is bad and that part dont cost too much another thing you should check before you do all that check make sure you have 220 volts on that plug if the switch is good and you have 220 volts it probably the motor or the timer they both or expensive
Jun 07, 2009 | Kenmore Dryers
Have a kenmore dryer model 110.96586400 it has a brand new heating element and will not blow hot air. what else could it be and were can i get a manual for this unit?
do you have 220 volts to receptical? if so check the thermal fuses in the back going to the element. the tub will turn on 110 volts maybe the breaker is only letting 110 volts to the dryer. i have seen it happen before.
Apr 18, 2009 | Kenmore Dryers
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
I have A kenmore Elite Model #110.65942400 Ser MR2103237.
before you take it apart make sure you have not lost 1 phase of the 220 volt line into dryer , dryers will run and appear fine on 110 volts be will not heat check fuse or breaker and re-set breaker even if it does not appear tripped , if fuse in line turn off power and remove fuses and check with an ohm meter , then if you have a volt meter check for 220 volts @ socket of dryer , then we will talk dis-assembly
Dec 01, 2008 | Kenmore 659 Electric Dryer
My dryer is not heating, but all other things works find.
CHECK FIRST TO SEE IF YOU ARE GETTING 220 VOLTS TO DRYER ITSELF WILL RUN ON 110 BUT WILL NOT HEAT , CHECK FUSES IF ANY CIRCUIT , RESET BREAKER EVEN IF IT DOES NOT APPEAR TRIPPED CHECK FOR 220 VOLTS @ SOCKET THEN TALK TEAR DOWN
Nov 25, 2008 | Kenmore 659 Electric Dryer
Kenmore 75180 Wall/Window Air Conditioner Logo
214 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
