Question about Panasonic Audio Players & Recorders
Can you hook up the panasonic subwoofer sb-wa820 to a pioneer receiver, purposely to get the full effect of surround sound
SOURCE: Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Posted on Jan 01, 2008
SOURCE: no signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Posted on May 14, 2008
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
Posted on Jan 24, 2009
  • 121 Answers
SOURCE: panasonic av control receiver sa-he200
On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
Posted on Feb 27, 2009
msnseb
  • 88 Answers
SOURCE: CAN YOU HELP ME
You can buy skytec universal connector cables for £5 from you local hardware store, or PA or musical instrument shop. Or On EBAY.
Posted on Jul 07, 2009
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Mar 06, 2014 | Pioneer VSX-823-K
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
How do I hook up speakers?
If you are referring to 5.1 surround you would have to have 5 speakers plus one powered subwoofer. The front left and right as well as your center channel to the majority of the sound reproduction with the rear channel being there for intricate sounds and background noise. The subwoofer will be a preamp output from your receiver. That signal will then get amplified by your subwoofers power amp. Generally subwoofers are tucked away in a corner while the other 5 speakers form a box around your viewing area.
Feb 11, 2010 | Pioneer VSX-453 Receiver
I have my vsx-1018ah receiver hooked up in for 7.1. Everything was fine for months. Now the back right speaker won't work. Speaker is fine, connection is good. Tried hooking up a different speaker and...
Assuming you're using the Surround Back speakers for their primary purpose, let's establish that there is something in the way of programming being routed to that speaker. Fire up the speaker level setup procedure and use any handy audio device (*) to see if a signal is present at the Surround Back Pre Out jack. If not, that speaker will never, uh, speak.
* For this test you could use your powered subwoofer. You DO have one, right? Just swap the RCA cable from Sub W Pre Out to the SB R Pre Out jack to see if anything appears there.
Jan 28, 2010 | Pioneer VSX-1018AH-K Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
CAN YOU HELP ME
Jul 07, 2009 | Audio Players & Recorders
Pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Jun 21, 2009 | Pioneer VSX-D510 Receiver
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
May 14, 2009 | Pioneer SX-315
What speakers are beneficial with this receiver? I want to have surround sound from my TV and also from my other components - CDs and old record player.
Well to get the full effect of 5.1 surround you will need 2 front speakers, 1 subwoofer, and 2 rear speakers. Personally I used 2 tower speakers, 2 rear speakers and a subwoofer. Match the speakers with the RMS wattage of your Receiver. (100x5) or roughly 50 watts per speaker. Yamaha, KLH, Philips are pretty good speakers.
May 13, 2009 | KLH R5100 Receiver
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
176 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
