Question about Compaq Presario Notebook
MICROPHONE My MIC not working as I am using Yahoo MSGN for calling to other computer
  • Abulwasiq Aug 15, 2008
    Thank you for trying
    I gone accordingly but still the problem. I connected the MIC in External MIC jack but my laptop not detected it. It might be Audio Driver problem?
    Sergeant:
    Champion:
  • 258 Answers
Yahoo messenger has to be setup to use a mic. There is a process you have to go through. Click Actions, then click Call Setup.
go through the menus...
Also Window make think it's in use already. Try rebooting.
Posted on Aug 14, 2008
  • Ken Williams
    Ken Williams Aug 18, 2008
    I was rated inappropriate. I think that you must have been mistaken. I said nothing inappropriate in my response.
    Thanks. Also, If only yahoo is not seeing the mic, than it's in yahoo that you'll find the answer.
    Ken
    second. rebooting solve problems because of how windows interacts with other programs. EG: not releasing resources like it should.
Yahoo voice call not working
Make sure ur mic settings are configured properly.
Open Yahoo Messenger Window, goto Actions > Call Setup as seen below:
Now follow the step by step instructions, and select the input and output source from the drop down menu on the setup screen until the microphone and speakers are working properly with this wizard.
Yahoo Audio Prefernces
Go to yahoo messenger main window , Messenger > Preferences > Calling & Audio
In this setup, select the microphone input from the dropdown, and similarly the speaker settings.
After selecting the proper input and output, the voice char worked just fine with me. Hope it helps you solve your problem.
Aug 26, 2010 | Yahoo Messenger
The microphone does not work. The webcamera function is working fine but when I went to download SKYPE, I realized that the mic was not working. Any suggestions on how to get it to?
Make sure of the following:
- The microphone is plugged in directly to the mic port either in the back of your computer or in the front (if this is available)
- Turn off any other applications that may be using the mic (yahoo messenger, Windows Live messenger, etc..)
- Go to the audio settings of the application you are using. Try to change the mic to another mic other than the default then test your settings
NOTE: Please rate our help to keep this free service online
Jan 08, 2010 | Compaq Presario Notebook
Vaio VGN-NW23SE no built in microphone indicator
your computer has a built monaural microphone. check your sound settings to make sure the mic is on. if the mic is on and there still isn't any sound on the other end then you might try an external mic. they work better as far as quality anyway.
Dec 23, 2009 | Sony VAIO VGN-N250E/B Notebook
Its not working If I want to make call using yahoo messenger. But it is working if I am only playing musics.
Options:
1. Test your microphone on other device/machine'
2. Check in volume control, options/properties if your mic is enabled.
May 01, 2009 | Computers & Internet
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
A4tech PK-7MAR
hello,
1. double click on volume icon on the lower right corner of your screen.
2. click on options, properties.
3. another sub window will appear.
4. in the box, look for mic volume and check on the box.
5. click ok after checking the box
6. another column should appear which is the mic volume. under the mic volume uncheck the mute box.
7. you should be able to use your mic now.
Note:
make sure you inserted the pink plug on the pink socket at the back of your computer.
Hope this post helps :)
Jul 02, 2008 | A4tech PK5
How increase my mic volume
a) to hell with calling india, they are as dumb as bush is.
b) click start > accessories > entertainment > volume controls. when the volume controls open, click on file (drop down menu) then select recording, then click ok. when the recording volume controls come up. select microphone as the default recording device, and make sure the mute box is not checked. slide the volume control slider most of the way up.
c) if you are using yahoo's call-out, run the audio wizard in yahoo messenger before making call.
d) plug your microphone into other 3.5 mm jacks on computer, and use window's sound recorder to see if the computer is picking up audio through the mic.
e) make sure your microphone's mute switch is not turned on (if applicable).
Jun 23, 2008 | Acer Aspire 5610 Notebook
My Logitech quickcam STX works only with mic webcam or mic with yahooIM
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Mar 01, 2008 | Logitech QuickCam Communicate STX Personal...
My computer is not detecting microphone when making internet phone calls.
Troubleshooting - Can't get voice chat to work.
Here are a few things you should know and check for to get the voice chat to work. · Firewalls - the voice chat feature may not work well behind company firewalls. Even though you can get other features of Yahoo! Messenger to work, the voice chat feature uses separate technology and may not work as well.
· Check connection - When you enter into a voice chat with friends, each participant should take turns trying to press and hold down the Press to Talk button. Everyone else should see their name turn red when they do that. If you see their names turn red, but don't hear anything, it may be a microphone / speaker problem, or it may be that we have more bugs that we need to fix. If you don't see their name turn red, you are probably having connection problems and that's why it's not working.
· Get the latest version - Please make sure that everyone who is using the voice chat feature has the latest version.
· Check mic and speakers - Check that your microphone works and that your speakers are turned on. Here's how:
* make sure the mic is plugged in correctly.
* adjust the mic properties.
- go to the control panel (start button -- settings -- control panel)
- click on the multimedia icon
- you should see a tab for audio
- make sure that the recording volume is set high.
* you can test your mic. by doing the following.
- Click the Windows Start button, then go to Programs, then Accessories, then Multimedia, then click on Sound Recorder
- A new window called Sound Recorder will pop up. Click on the record button (a red circle), then say a few words, then click the stop button (black square).
- Click the play button (black triangle).
If you can hear yourself fine, then your microphone is okay. If you can't hear your voice using Sound Recorder, the voice chat should not work either.
Jan 12, 2008 | Toshiba Satellite A105-S4334 Notebook
Not able to speak with mic while using messengers
when in yahoo messenger go to actions then call setup, this will set your microphone up within messenger and let you use it. You may need to try all three types of microphone on the drop down list in messenger to set yours up correctly.
Nov 18, 2007 | Compaq Presario Notebook
Compaq Presario Notebook Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
