Question about LG 32LD350 32 in. LCD TV
Just set this new tv up. It has a great picture but no volumne. When going to audio to try and program it's not highlighted so cannot get into it. Give a pop up that reads "wired headset connected" we do not have any headset connected. How can we get volume to work.
  • 1 more comment
  • tntbaker May 18, 2011
    I cannot get to my "sound mode" as I said earlier it is grey. Not highlighted so dies not allow me to scroll over to it. What do I do to get it highlighted so I can reset?
    i do not have a remote ! This tv was a display model and did not cone w a remote. Can I program my satellite remote to it then fix the volume issue?
  • tntbaker May 20, 2011
    I now have a remote fr tv - pushing the mute button did nothing to turn earpiece off. Earpiece jack is not faulty- plugged in earphones and they work fine. Just can't turn that option off. Audio functions still not highlighted so doesn't allow any changes. What to do?
  • LG Master
  • 2,098 Answers
You may follow the steps below.
First check the speaker set-up on the menu.
> Go to menu(Audio setup)
> Scroll down to the Tv speaker
> Select on.
If the steps above didn't solved the problem, let the unit back to Audio factory settings.
> Scroll down to sound mode, then reset.
> Select reset, then enter.
Let me know if the symptom still there.
Jdvillanueva
Posted on May 18, 2011
  • 1 more comment
  • Jdvillanueva
    Jdvillanueva May 18, 2011
    Please press the "Mute" button and let me know if the symptom still there...
  • Jdvillanueva
    Jdvillanueva May 19, 2011
    I want you to hit the mute button on the remote because it will shuts off the headset, and will confirmed if the earphone jack is faulty. I've suspected that you're earphone jack is faulty. Once the earphone jack is faulty, you must replaced it with new one or you may spray directly with electrical contact cleaner while inserting and pulling the earphone plug to clean its contact.
    Some dish remote can use as a universal remote to control other devices. Instructions and codes is listed in its supplied manual.
    You may click this LINK to order online for the replacement of your remote control.
  • Jdvillanueva
    Jdvillanueva May 20, 2011
    If you hear the sound from your earphone, this is a proof that the earphone jack is faulty that's why the you can't access it to the menu.
    I will explain to you why.
    When you plug-in the earphone to the jack, this jack has an internal switch that will switch off the sound from the tv speaker and same with the access to the menu. The problem here is, when you pull-out the earphone the internal switch will back the sound to the tv speaker. The internal switch is stuck to earphone that's why the sound can't come on to the tv speaker. You must replaced this jack to cure the symptoms...
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
I dont have any sound on my p50xha10us
Just check this set connected to any external audio devices, such as an amplifier. Use TVs'audio out connections to the audio in connections of the amp, and see whether the amp produces sound. If yes, the fault will be either to the inside speaker of your set, or its audio output card. If there is no sound produced by the amp too, the digital processor section of the TV's main board is faulty. The main board has to be replaced.
Sep 27, 2012 | Fujitsu P50XHA10 50 in. Plasma Television
No volumn
Sub another set of audio/video cable, if no change! hook the DVD player to another TV set to rule out the TV'S if there is no change, far cheaper to replace player.
Mar 20, 2012 | Televison & Video
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
I set up to make a wav cd and get the message: "write error in volumn administrator." what do I do?
It sounds like the program is trying to access things it's not allowed to. Have you tried running it as an administrator?
May 03, 2011 | Cakewalk Pyro Audio Creator - Windows CD...
Centre input active
Go to..
Menu / Setup / Source
Scroll down and Highlight Center Input, And select Off.
If it dont work first time round, Disconnect all Audio/Video leads from TV, and try again.
Jan 22, 2009 | Philips 42PF9966 42 in. HD-Ready Plasma...
Vivitek
check the settings on your TV, my new TV was set to analog on the audio screen, in which no sound came out after I set it on the digital mark, sound was there, I hope this will help you
Sep 06, 2008 | Vivitek V37835 46 in. LCD Television
No sound in television
Go to your menu.
go to sound or audio. look for any audio output options and disable them.
Does your audio go out while you watch antenna tv or when you watch a dvd/game?
Aug 06, 2008 | Televison & Video
RCA 46 in rear projection
The first thing that I would check is in the audio menu to see if it is set on the SAP mode (secondary audio programming). If it is and there is no audio being broadcast on that channel, then you would have to turn SAP to off (which is usually what it is set to). Now there have been problems with the audio dropping out on regular CRT style RCA televisions where the audio would drop out, and you had to unplug the set for about 30 seconds to reset the TV, and I would try that next.
Dec 19, 2006 | RCA P46921 46" Rear Projection Television
LG 32LD350 32 in. LCD TV Logo
188 people viewed this question
Computer Repairing
Computer Repairing
