Question about Epson FX-2190 9 PIN Matrix Printer
After clearing a jammed paper - upon turning on Epson fx-2190 goes into alarm with a constant beeping
    New Friend:
Tener presionado el boton de microajust y pause durante 5 segundo sin soltarlo y se resetae ok
saludos
Posted on Mar 28, 2014
hvpatel
  • 152 Answers
SOURCE: Paper Jam
because of your paper sensor is not working or jam
Posted on Feb 29, 2008
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
Hy everybody... I have the same problem... tried to reset as told above but nothing happened.
When I try to use ADF I hear a little "click" inside it, without any paper advancing.
Any further suggestions?
I already bought last year a new adf due to a fatal error of the previous!
Posted on Apr 01, 2008
pauman
  • 248 Answers
SOURCE: Epson FX-2190
What operating system are you using? In Windows, you can set it through server properties in the Printers area of the control panel, you can do this by creating a custom paper size. If you are running in DOS, you can set the page length through the printer itself by going to its default setting. In the printers default setting, make sure you are setting the length on the correct paper path (FRONT FEED, BACK FEED).
Posted on Jun 24, 2008
guide2u
  • 461 Answers
SOURCE: Epson FX-2190 Matrix Printer
No, only one time installation is sufficient. You might see problem if you install wrong driver on the wrong O/S..
You may find details information about epson FX at http://etech.maiila.com/epson-fx-2190-driver-software-download-including-for-vista
HOpe this helps.....
Posted on Sep 09, 2008
doc_delphi
  • 11 Answers
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
Epson FX-2190 gives 5 beeps at startup and then continuously flashes all lights.
These beeps and flashes are fault indications with paper transport mechanism. If you wish to get more details about these, check the site linked here.http://electronicshelponline.blogspot.com/Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 17, 2013 | Epson FX 2170 Matrix Printer
My epson fx2175 keeps on beeping after initializing when i turn it on
check if paper in inserted correctly, the paper sensor might be broken.
check where the paper goes in, in the back.
Apr 14, 2011 | Epson FX 2170 Matrix Printer
MY EPSON FX1180 CONTINUOUSLY BEEPS, SOMETIMES 1 BEEP, 2 BEEPS AND SOMETIMES EVEN 3 BEEPS. THE PAUSE LIGHT ALSO STAYS ON WHEN THIS OCCURS. WHAT CAN I DO TO RESOLVE??
There are several sensors and switches that could be faulty or obstructed. Make sure cover is closed - would give a "cover open" indication. Check for paper stuck inside - would give a "paper jam" indication. Especially if you have ever printed labels, you may have to dismantle a bit to clear out gummy residue that acts as a paper catcher.
Feb 18, 2011 | Epson FX 1180 Matrix Printer
I am trying to send a dos file for printing to epson fx-2190. althought i have set the character table to 437-Greek my printer does not print greek alphabet
You would probably need to set the printer DIP switches to print Greek, however it is quite possible that this is not possible. Get hold of the printer DIP Switch settings and check. Alternately you will have to try the exercises using a GUI operating system to print the selected font style.
Jan 16, 2011 | Epson FX-2190 9 PIN Matrix Printer
Epson FX-2190 keeps on printing unknown characters
The print que on your computer may still be trying to send processes to the printer. Even if you uninstall and reinstall the printer it can be reloaded on the same port as before. Open your print que and see if anything is pending. Hope this helps.
Aug 20, 2009 | Epson FX-2190 9 PIN Matrix Printer
Aug 29, 2008 | Epson FX-2190 Matrix Printer
Epson FX-2190
Jun 03, 2008 | Epson FX-2190 9 PIN Matrix Printer
Epson FX-2190 9 PIN Matrix Printer Logo
133 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
