Question about Sony STRDH710 71channel AV Receiver with 6 HD Inputs 3 HDMI 3 Compone
I have bought new STR-DH710 120v AC 240w, in my place we dont have 120v ac power what will happen if i use 240v ? Kindly advice
You will burn your reciever up. and warrantee will not buy you a new one. have your electricition install some 110-120v AC lines
Posted on Jun 14, 2013
Hullo guys, i recently purchased a shaving machine with a power adapter that can operate at a voltage of 120V Ac and frequency of 60 Hz. Now unfortunately here in Kampala, Uganda our Op. Voltages and...
You need a step down AC transformer 240V to 120V then you can connect the shaver to the 120V outlet. You do not need to worry about the frequency.
Jan 22, 2013 | Office Equipment & Supplies
Where can I get an AC power cable for the Sony STR-DB 798 surround sound receiver?
Hello
AC cables can be bought from most of the electronic spare part shops. You have to note the input plug of your Sony device. There are so many types of them according to the country to which they are supposed to release. I don't know where are you from now. Check the cable's pin to suite your devices' AC input socket. Select a best quality one. Thet is all to be in mind. OK.
Jun 06, 2011 | Sony STR-DB798 Receiver
I cant find power cord for my wd 1tb portable harrd drive what voltage ac plug can i use? D33015 N3565 E101559 THOSE ARE SOME NUMBERS ON HARD DRIVE
Dear Dodgeydude
you can buy the adapter directly from http://firstmybookexternalharddrivezone.blogspot.com/2011/02/pwr-ac-adapter-charger-switching-power.html
where as the specifications are Input : AC 120-240V Output : DC 12V 2A (1.5A Compatible)
please dont forget to rate
Gagan
Mar 15, 2011 | Office Equipment & Supplies
Where can I order a new power cord for a coby portable dvd player TF-DVD7006?
Hello and Welcome to FixYa!
It seems like this is a discontinued item. Specs on the AC adapter are listed as:
The AC adapter operates on AC 100-240V ~50/60Hz (DC Out: 9V; DC
Current: 2.0A minimum
Your best, quickest solution is to check with a place like a Radio Shack who may have a universal adapter with the correct fittings to plug into your player.
Concerned.
Jan 28, 2011 | Coby TF-DVD7006
Hello everyone, you are my last hope. Here is my story I have a Triton Le bought in Mexico in 2005, it has the American AC/AC power supply cable. I moved to Europe and there I bought a 240V INPUT (9V...
I have been trying to find a schematic, however the damage should be limited in the unit.
Since there is only 9VAC input, we know that it has to go through a rectifier and a filter capacitor and then likely a regulator. I doubt the problem goes beyond the regulator.
The screen light MAY be independent of the logic power in the unit, the LED's will NOT be independent.
The voltage rating of the fuse is NOT a problem.
You likely blew out the rectifiers as a start. They may be individual diodes or a small module with four diodes inside.
The diodes SHOULD have survived but check them with an ohmmeter on the diode range. The Filter cap may be destroyed, and alsothe regulator which is likely a three terminal one like a 7805.
Aug 11, 2010 | Korg Pa800 Synthesizer
What is the wattage for the WS-65411?
POWER
AC 120V 60Hz
240W
Only WS73411 takes 275W otherwise, all other model with this series like
WS48311
WS55311
WS65311
WS55411
WS65411
WS73411 take 240W as yours.
Hope you are talking about main wattage. Audio wattage is exceptional.
best of luck
Jan 27, 2010 | Mitsubishi WS-65411 65" Rear Projection...
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Will not power up although there is 240V AC at the input. Power switch on the front will not work
So, maybe try 120V AC......  Or can you set it for 120vac or 240vac?  Set it to where it should be.
Jul 12, 2009 | Sony STR-DE315 Receiver
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Sony STRDH710 71channel AV Receiver with 6 HD Inputs 3 HDMI 3 Compone Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
