Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
My electric Kenmore oven doesn't have power and is not working ?
  • Kenmore Master
  • 3,053 Answers
Hello, eparsa
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Kenmore 790
I could be wrong, but from your limited description I am assuming that you cut the cord and wired direct to the box. You may not have 240 volts at the box and are trying to connect it to 120 volts. A dark green wire is the safety ground. The white is neutral and two colored wires are supply lines with 120 volts ( average) EACH. Better get someone in there that knows electricity and how to make proper connections to the proper voltage. Otherwise you are asking for major trouble.
Jun 26, 2013 | Ovens
Oven doesn't light
check to see you have power then check the heater coil is working
Dec 02, 2011 | Kenmore Ovens
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
User_Manuals kenmore c970
Useing a flash light look at the element for bum's or damage if you see damage anywhere on the element turn off the power and replace the element , need help finding the part get back to me with the info and i will locate it for you
Oct 29, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
Power was disrupted and stove needs resetting
Try turning the power off to the oven totally and leaving it for a few mins, then turn it back on. If this doesn't work you may have to have a new clock/timer. espares used to have them. If you don't see it listed, send in a request.
Jul 29, 2011 | Stoves 720EF Electric Double Oven
On a Kenmore gas oven the flame goes on and off and doesn't keep a constant temperature.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 19, 2011 | Kenmore Ovens
The oven of my Chef 635 model GSC6635SLP doesn't ignite (no gas comes out in oven, yes from plates), the ignition element is working, there is electricity in terminals connected to thermo valve but it...
heatman101
Jul 13, 2011 | Ovens
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
My kenmore oven doesn't work. There was a poof and cloud of smoke from the back of the stove when I turned it on and it now longer works. The stove works fine. The clock doesn't light up anymore...
ISOLATE MAINS POWER BEFORE OPENING PANELS
It sounds like you have acomponent blow, (stating the ob), what I would recommend is a visual inspection. remove panel on rear, have a good look at wiring and conponent that are visable. If no sign of black short on terminals it may be an element. The fault could be in the panel circuit but that would not produce enough smoke, a fan motor can an element and a electric switch, they use the two terminal type mounted usually on the chassis, if this appears burnt out replace with the same temp type. To go further you will need electrical knowledge, and a test meter. Let me know if you require further assistance.
John
May 20, 2011 | Kenmore Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
47 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
