Question about Westinghouse 26" LCD Flat-Panel HDTV
When i turn on my Westinghouse LTV-27w7-HD,there is an loud screeching noise and most times after a few minutes it clicks in and then it's fine,can you help?
  • Westinghouse Master
  • 2,098 Answers
This is an indication of out-of-regulation condition on the power supply section. The caused of this symptoms is the leaky/dried electrolytic filter capacitor in the power supply section. It will dropped the supply voltage and sometimes it produced an overload to the chopper transformer and produces that kind of symptoms. It needs a little warm-up to make itself stable but the symptoms will get worst, time will come the unit will not power up at all.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can easily be identified while dried capacitor has no physical indication of fault. You must have a capacitor checker to determine its condition. If it is not available, you may replaced all electrolytic capacitor in the output of the power supply section. It has a capacitance and working voltage which is labelled on its body itself. Replace it with same rating. Upon installing a new capacitor, ensure that the polarity (positive and negative side) must be at its location to avoid further damaged. It will not cost you much because each capacitor cost only less than a dollar. Also if you are going to DIY, you will save $200-$300 for service fee of the technician.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified technician to isolate the problem.
Check also if your unit is still under warranty/warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 18, 2011
How can i get service manual for westinghouse tv model 42B 8000 series 7
Try to go this link http://www.retrevo.com/support/Westinghouse-LTV-27w7-HD-TVs-manual/id/278dj978/t/2/ it might help
Jun 25, 2011 | Westinghouse LTV-27w7 7 in. LCD HDTV
Tip
Westinghouse LTV-27 Manual Download
Download Westinghouse LTV-27 HDTV User Manual
Have you misplaced your Westinghouse LTV-27 HDTV User Manual?
Would you like a digital, searchable, pdf version of the Westinghouse LTV-27 HDTV Instruction Guide?
Follow this link (& click FREE) to download a pdf version of the Westinghouse LTV-27 HDTV manual.
I hope that helps.
__________________________________
on May 08, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse LTV-27w7 HD 7 -- after a storm - the tv was the only thing affected in the house. The light comes on when the power is turned on, yet nothing else comes on - no picture and it will not turn...
same thing happened to my lcd. I had it checked out and the specialist said it needs a new motherboard. You can order one @ shopjimmy.com for under $200. Just swap it out. Hope this helps
Aug 14, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
My dryer make a loud noise when its rotating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
jkgjh
Feb 16, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV27w7. I turn it on and it almost
there is a PSU output or Inverter Board defective. Needs to be checked
Dec 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
My Westinghouse LTV-27w7 Black out
the high voltage circuit is shutting down.
the two most common faults are the flyback transformer,and an overvoltage condition from a blown regulator.
both are repairs where the tv is thrown out.
the days of the loose wire are gone.
Aug 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
LTV-37w2HD37"Flat PanelLCD HD TV
It is fixable, but at a huge cost. A new panel can cost more than the TV. You might be able to find one with a good panel used on Ebay though.
Jul 13, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Westington LTV-27w7 HD black screen
ICheck the power supply connections make shure tht the plugs are seated correctly. The power supply isreplaceable as a complete uitand you have to return a repairable unit.
loumargo
Allied electronics
loumargo@verizon.net
Westinghouse 26" LCD Flat-Panel HDTV Logo
70 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
