Question about Euro-Pro Shark 80 - 7133
Hello, I have a Shark euro-pro sewing machine. I am sewing denim on denim using singer needles that were suggested for denim. The numbers on the package are 2020 110/18 808 R 130/705H 05 un I have not oiled the machine and have had it for 4 years. I have been sewing this denim daily for a few weeks with no problem until tonight. The top thread on my sewing machine keeps breaking. Any suggestions? Thank you, Emilie
  • 415 Answers
The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
The majority of the time it is one of these things that will cause the top thread to break.
Posted on May 18, 2011
Euro-Pro Shark Sewing machine needle off center, hits needle plate
it sounds like the machine has jumped time & needs to be retimed
at a sewing machine repair shop.
I also suggest you throw away that denim needle, it's very
lightly damaged.
Sep 12, 2012 | Euro-Pro Sewing Machines
Where to get sewing machine parts. I need a new auto needle threader. I bent the one on my Shark 9110.
any chance that it looks like this one?
www.sewingpartsonline.com have this part but list it for the Euro Pro Shark 9015
However, you could email them and double check its suitability for your model.
http://www.sewingpartsonline.com/needle-threader-simplicity-singer-white-270030002.aspx
Nov 08, 2011 | Euro-Pro Shark 9110 Sewing Machine
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
What size needle does the euro-pro x 384 take?
The needle size depends on the type of fabric you're using. Generally, if you're sewing heavy or sturdy fabrics you'll need a size 16 needle. If you're sewing light weight fabrics, you'll need an 11. Nowadays, most machines will take any brand of needles. I hope this helps. If it does, please return and rate my suggestion.
Jun 06, 2011 | Euro-Pro Shark 60 - 384
How to thread euro pro 380a sewing machine lost mannel
My needle will not pick up my bobbin? I have tryed everthing! my bobbin was placed in the holder right. my needle is in the EP correctly! not sure if my Thread is correct in my machine. but I have read the manual and still cant get the needle to pic up. Can some one help me out on this! Euro-PRo 380A
Dec 16, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
I need a replacement Auto needle threader. There seems to be no where that I can find the pat numbers for anything on the machine....Euro-Pro 9106 Deluxe Denim & Silk sewing machine.
I've never had an auto needle threader work properly for very long. My suggestion is to not bother to replace it and just relearn how to thread the needle. Sorry.
Jan 13, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Trhreading
http://cgi.ebay.com/Euro-Pro-Deluxe-Denim-Silk-Sewing-Machine-EP-377_W0QQitemZ8271336746QQcategoryZ3118QQcmdZViewItem#ebayphotohosting If so it threads just like my sewing machine.Draw your thread across the top,down into the first slot,then up and thru the second slot,come down,pass it thru the thread guide on the needle,then thread your needle.Most all machines are basic when it comes to threading.HTH
Kathi
May 20, 2009 | Sewing Machines
Needle breaks on my Shark Euro-pro model 361 my
Are you inserting the needle fully into clamp? You may have a bad lot of needles that werent straight. Try sewing by hand with machine to see exactly where and when needle breaks, then you might be able to solve problem.
May 04, 2009 | Euro-Pro Shark 60 - 384
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Thread keeps breaking
Check the direction of the thread while threading the needle. I had the same problem and it went away when I threaded the needle from the opposite side of what I was doing.
May 08, 2007 | Euro-Pro Shark 80 - 7133
Euro-Pro Shark 80 - 7133 Logo
122 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
