DVR I AM USING HAVE OPTICAL OUTPUT AND MY LG HAS A DIGITAL OPTICAL. DO I HOOK DVR OUPUT TO THE LG OUTPUT?
  • 111 Answers
If ur connecting and optical output plug it in the optical output on the tv does not matter if it says digital optical output
Posted on May 18, 2011
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
HOW I GET SOUND TO COME OUT OV MY LG HOME THEARTRE SYSTEM USING AN OPTICAL CABLE FROM MY LG 37" LG3000 TV .AND HOW DO YOU USE THE SIMPLINK FEATURE ON THE SAME TV . NO INSTUCTION MANUEL. THANK YOU.
This is a manual that should help you, it may even be your model but, it shows hook ups and has a page about the Simplink:
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=37LH30&matchedModelCode=1000009240&searchEngineModelCode=37LH30&initialTab=documents&targetPage=support-product-profile#
Scroll down to manual, ckick on the one you want, and open. Typically, you would want to hook all video related units directly to TV, via HDMi, Component, RCA, etc., with the componenet video, you have to also have an audio cable, because the componenet does not carry sound. In other words, you want to hook things like, cable/sat box, DVR, etc., directly to TV then, use your digital optical out from tv to digital optical in on your home theater. You use your TV's menu to select what you are watching and you only have to use the one input setting on receiver to listen to all. If you try to route you units through the home theater system first, you may not get the best results and you may expierience lags between the video and audio.
Jun 12, 2011 | Audio Players & Recorders
I have an HD PVR (Explorer 8300) and have connected to my Samsung TV using HDMI cable. My question is can I connect my SONY STR DE605 receiver or do I need a new one?
Depending on your tv output, you shpuld be able to hook your TV to receiver via audio output. Running your video components through your receiver will not give you the best performance anyway. Run your HD DVR to TV the way you have it then, if it's possible to run audio out from TV, via, RCA, digital optical, etc., to your receiver. The sound will be transfered through the TV. You may also be able to utilize component out from your HD DVR and a separate audio cable.
May 22, 2011 | Sony STR-DE605 Receiver
Hi, how can i hook up a wireless 5.1 headphone to a denon avr-3808 using an optical connection. I can't find any optical output port on the denon amplifier.
My manual shows two optical outputs labeled "2 (DVR)" and "3 (VCR)" at the upper right of the rear panel.
It's unclear what will appear there when playing any particular analog source.
Feb 26, 2011 | Denon AVR 3808Ci Receiver
How do i hook my bose cinemate system to my lg tv?
If you lg has Optical Output, Which is a 20.00 Toslink Cable, You hook the cord into the Tv using the Optical Output Port then run to the optical in or DIGITAL In on the Cinemate, If you don't have the option to run optical Check for Red and White Monitor Out from the TV and Run into Red and White on the Cinemate.
Dec 15, 2009 | Bose Cinemate Digital Home Theater System...
Problems with optical input. I am having intermittent problems with the optical sound input on my Onkyo. I am using a DVR with optical output for the source. Sometimes when I turn the DVR and Onkyo on I...
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Dec 07, 2009 | Onkyo TX-DS747
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Optical input from Sony PS3 Playstation.
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Mar 13, 2017 | Jamo DVR-50 System
Getting no audio to game systems, pc connect won't connect
I also had the same problem when using my optical output for DBS and DIGITAL DVR/DVD.. you need to change the setting for this by on the remote changing to either analouge..rca sound input or Digital...for Optical input. The same problem cuaght me oput for a long time as well. The button is when you slide down the remote cover and the button is called analoug /digital
Dec 30, 2007 | JVC RX-D301S Receiver
Digital audio problems
Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
Mar 11, 2006 | Pioneer DVR-5100H DVD Recorder
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Electro Med Services...
