Question about Motorola Mobility RAZR V3
My message sending has been failing,please help me to recover it.
Sending failed message barred
First of all check all the sms setting. > Open message> message setting>> sending profile >> message center number>> correc the center no. by referring using another phone with same network operator.Secondly, check the "send via same center" choose "NO". The above steps might varies to phone so please use the steps for help.Thank you
May 30, 2013 | Nokia 1100 1101 1108 1110 1112 1200 1208...
Message sending failed in sony ericsson w700i all senders message is coming but when i reply to that mesage or text to contact person that is shows sending failed so please help me
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Sep 12, 2012 | Cell Phones
I mistakenly delted an sms without the necessary backup . My SIM shows no txt and I do not have any idea how to recover this . Please help. B
GT Recovery for Windows download from: www.gtrecovery.net
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup.
This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Watch this video and share it with your friends too so that they can also get their precious lost data back.
Feb 28, 2011 | Cell Phones
Sending failed
Only two reason for sending message getting failed,
1) Check your meaage center number, call the customer care to confirm it
2) The Network may be busy, wait for some times and try sending it again
ENJOY! RATE THIS SOLUTON
RNJ VINOD KUMAR
Sep 12, 2009 | Sony Ericsson P990i Smartphone
When i send a message atonce it gives the response "message sending failed." message is not sending from my mobile phones. please provide me solution to solve this problem.
Delete messages in sent items.It should work now..... If not make sure that message centr no. is the right one. Contact customer care if u dont know message centr no. If problem persists, use some other handset and try sending message.If message sending fails in other handsets too then priblem is related to SIM or network.Complain to the customer care.Wait for their response.If the network is OK,then the last option is to apply for replacement with a  new SIM .!!!
Apr 13, 2009 | Nokia 2310 Cellular Phone
Message failed
than check message sending profile
than check message sending no.
last opection is Reset ur mobile setting via restore factory setting
Sep 20, 2008 | Sony Ericsson P990i Cellular Phone
Texting problems
check if u have enough balance to send the message.
May 26, 2008 | LG Shine KE970 Cellular Phone
SMS sending failed
Please try this to find a solution to your problem. Go to Messaging window and select More. Select Settings and SMS account subsequently. Make sure that the 'Connection Type' is 'GSM preferred'. And in the 'SMS Service Center Address' check with your operator Customer Care and make sure the same number is entered. You could tell the Customer Care of your problem and that you wish to verify if your using the correct service center address.
Hope this helps
Mar 22, 2008 | Sony Ericsson P1i
Motorola Mobility RAZR V3 Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
