Question about Acer 19" LCD Monitor
I have taken acer lcd monitor on march 16 2008, the power to monittor is goning to on and off frequently while running..? and monitor is on and off itself, when it is start acer symbol is coming within one minute it goes to off and start itself....
  • 11,361 Answers
2 years old may be due for bad DC filter caps inspection which is very common failure on LCD TV's and monitors.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 18, 2011
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
My acer aspire fell. when i tried to open it. there is light on the power button but there is no picture on the screen. is there still a chance for my acer aspire notebook to be revived?
There is a chance of the LCD going bad.. If you have any external monitor try to swap the display on a external monitor.. If it woks well then the LCD has gone bad... If it doest work on that as well there might be more parts that have gone bad.. Contact the computer manufacture to get it fixed...
Sep 24, 2010 | Acer Aspire One PC Notebook
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
Trying to hook up my monittor to my hp m480n PC
This should be fairly simple if you have a montor cable 15 pin you can find them at any office supply store like staples or office max.
good luck with it.
Jan 09, 2010 | Smart Modular PYXSCAPE SV1170 17" Flat...
Acerx193hq monitor keeps turning off only just started doing it purchased march 2009 have to press menu on monitor comes on then goes off again
Hi
Capacitors going bad are causing this problem. Call Acer and let them know. It may still be in warranty, if not it should certainly qualify. Parts age in everything electronic but LCD monitors should have at least 2 years of use before parts begin to change value.
Thanks
Jul 21, 2009 | Acer AL1916W 19" LCD Monitor
My new Acer P191W LCD Monitor has a high pitched whine that is extra loud on pages with rich and dark colors.
The PSU "power supply unit is taken on a lot of noise from the outlet. Can you tell us if you have it streight plugged into to a 120V AC outlet or is it plugged into a strip? The Solution for both is NEW strip i recommend APC or plug it into a strip and check the outlet and make sure its properly grounded this should shore up this problem or the unit itself is going out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 24, 2009 | Acer P191WBD LCD Monitor
Power up aborts
thanks a great link
Terry
Mar 30, 2008 | Acer Aspire 5610-4648 Notebook
Acer AL1714 17" LCD Monitor Good Power supply no power on monitor
Hello, I have to same problem. I returned my monitor to Acer but got it back unrepaired, they could not see the malfunction. But I kept on sending it back, until I got a new model. Now after 2 years I get the same thing with this monitor. But there's no warranty anymore, so I looked into the problem myself. I found out that inside the powercircuit board is connected to the mainboard through a 10pin connector. The 5 pins that are on the lowest row, show a trace of white powder, I suppose occidation. I sprayed a little of contactspray in it. I must say the problem is not gone, but much better. The problem shows not so frequent anymore and lasts not so long. At first the screen switched of for 3 to 5 minutes and came back on. Now the screen is gone for perhaps 1 second and returns. So I'm almost convinced the problem has something to do with the connection of the powercircuitboard inside and the mainboard inside, when the monitor heats up a bad connection occurs due to occidation of the 10 pin connector. If you find a solution that fixes the problem 100% let me know, please. Mario.
Dec 05, 2006 | Acer AL1714 17" LCD Monitor
Monitor will not power up
Hi tafkab, Sounds like it's probably the backlight inverter board. Try the test I have at the bottom to see. It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, Dude
Nov 25, 2006 | Acer AL712 17" LCD Monitor
Acer 19" LCD Monitor Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
