Question about Frigidaire GLRS237ZA Side by Side Refrigerator
FRIGIDAIRE GLRS237ZA ...NOT FREEZING FOOD ALL THE WAY...FIDGE PART SEEMS WARMER TOO...UNPLUGGED LET SET NO WATER SEEMS TO RUN JUST NOT WORKING PROPERLY..ANY HELP
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
  • 121 Answers
SOURCE: GLRS237ZA
sounds like the tempreture thermostat in the fresh food is not sensing the tempreture properly, or the damper assy. is not closing or stuck open. you need to replace the thermostat for the fresh food section or the damper. their is a control box kit available
by frigidaire part # 5303918283 that will solve your problem.it has the fresh food thermost,the frz thermostat the damper and the board all together it retails for 235.99 -299.99. seen it at sears for 179.99. ,price just recently went up on these kits we still have one left for 129.99 + tax. + shipping . shop around and search for the best price .you will need that part # to search for part. good luck contact us if you need to orer or have any aitional questions. thank you
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE : allbrandsappliancerepair.com
email ; customerservice@allbrandsappliancerepair.com
Posted on Jul 11, 2008
awcforever
  • 359 Answers
SOURCE: Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Posted on Jan 30, 2009
SOURCE: fidge freezer is not working properly
Get british gas homecare cover for heating and appliances, don't tell 'em the freezer isn't working, then a month later report it as a fault, they'll fix it. Unscrupulous i know but what can ya do? Otherwise get a hotpoint engineer, sign up for their maintenance plan.
Posted on Apr 09, 2009
louislevel_2
  • 374 Answers
SOURCE: frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
Posted on May 05, 2009
Fresh food compartment is too cold.
It's ether a bad thermister out thermostat or a damper stuck open I would guess.
Sep 03, 2012 | Frigidaire GLRS237ZA Side by Side...
Refrigerator freezing food
Fridge thermostat dials are often problematical due to the ones that are numbered 1 to 10, is 1 the warmest or the coldest as the number is lower? Some companies put 'warmer' and 'colder' which avoids confusion. My advice, put it in the middle '5', and leave overnight, check the temperature in the morning with a fridge thermometer. Then change the thermostat dial to 8, and check it the next morning with a thermometer. The next day put it on 1, and leave overnight, check the temperature in the morning. If the thermostat has gone, all three morning temperatures will be the same.
You mention 'or as your website suggests', you know we are not Frigidaire or anything to do with the retailer? We are Fixya, people just like you, helping others. I am a caterer, and just happen to know about fridges. I get them repaired professionally, but always ask for a full explanation of what went wrong. We recently had a sandwich storage fridge that was freezing food, and it was the thermostat that needed replacing.
The things you did, cleaning the coils, will actually make the fridge run colder. The Defrost Thermostat is unlikely to be the problem, as when they don't work, the evaporator, the part that is where the chilled air comes from turns into a block of ice. When that happens, air can't pass through it and the fridge warms considerably.
Due to the damage this freezing is causing with your water and filter, I would suggest you call a service engineer and get it fixed professionally as you will be swapping out parts that are fine. Correct diagnosis is the key, and they will also check the gas pressure at the same time. Consumers can't work with refrigerant gas, it is *******.
Mar 14, 2017 | Frigidaire Refrigerators
I have new gallery frigde, from frigidaire. And the ice bin is taking forever to fill. the water dispencer is working, with pressure, as well.
The water has to first freeze before it will dump into the bucket. Once it is filled, it should stay filled depending on how much ice you use.
Nov 30, 2010 | Frigidaire GLRS237ZA Side by Side...
The air vent between my freezer compartment and fresh food compartment below is frozen over and as a result, the fresh foo d compartment gets too warm. I have a Frigidaire refrigerator, model FRT8B5EWA....
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jun 29, 2009 | Frigidaire FRT8B5EW 30" 18.2 Cu. Ft. Top...
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Fridge is freezing food on upper shelves
Either damper assembly between fridge and freezer is not working correctly or the thermostat is bad
Sep 05, 2017 | Frigidaire FRS26H5AS Side by Side...
GLRS237ZA
TAMPA FL 33624
FAX # 813-908-5559
Jul 11, 2008 | Frigidaire GLRS237ZA Side by Side...
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
155 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
