Question about JVC AM FM CD DET FACE CAR STEREO
Do the jvc kd200 have bluetooth feature - JVC AM FM CD DET FACE CAR STEREO
What is bluetooth adaptor for jvc kd s28
According to the installation manual for the KD-S28, the bluetooth adapter is KS-BTA100. You can find this on page 2 of the installation manual which is available from JVC's support page: http://books.jvc.com/ . Enter the model number and click the Model Search button. The direct link to the installation manual is http://books.jvc.com/Download/119824748/GET0754-002A.pdf .
I hope this helps. Amazon has a couple of the adapters for sale: https://www.amazon.com/JVC-KSBTA100-Add-On-Bluetooth-Adapter/dp/B004REMUJE . Other vendors do not report having this in stock.
Mar 27, 2017 | JVC Car Audio & Video
JVC KW-R920BTS. Clock is set to correct time. When connected to BlueTooth, clock jumps ahead one hour.
So the device connected via Bluetooth is advising the unit of the time because the device is calling the shots. One device is set for local time and the other is summer time. Change the setting on the Bluetooth phone or whatever to local.
Non one else has encountered this problem according to my search.
JVC KW R920BTS jumps ahead one hour when connected to bluetooth device...
Nov 28, 2016 | JVC Car Audio & Video
Bluetooth feature is available or not in Jvc Kd-R504
The KD-R504 does not offer Bluetooth functionality.... Sorry.
Jun 19, 2016 | JVC Car Audio & Video
I have a jvc kd s88bt car audio system need info. About how to use it.set up , commands, settings adjustment buttons how to use them to st up Bluetooth
The instruction manual can be downloaded from http://books.jvc.com/booklist.asp?Model=kd-s88
You may research on http://www.jvc.net/cs/car/bluetooth/index.php for bluetooth compatibility.
Feb 19, 2015 | JVC Car Audio & Video
How to connect my mobile through bluetooth with my JVC KD-DV5606????????
I suspect this model is equipped with BT feature. BT car kit is affordable now. Attached link is for one that plugs into the radio's aux input.
http://www.lightinthebox.com/bluetooth-car-kit-bluetooth-receiver-stereo-bluetooth-adapter-factory-direct-private-mode-3-0-edr_p2171690.html?currency=USD&litb_from=bing_shopping&utm_source=bingshopping&utm_medium=cpc&utm_campaign=bingshopping
Dec 13, 2014 | JVC Car Audio & Video
Is jvc kd-g335 blue tooth compatable
If it is a "Ready for BlueTooth" model you will need this adapter JVC KS-BTA20
Jun 04, 2009 | JVC KD-G340 Car CD/ MP3 Player
Blue tooth compatible Car stereo ..and LG Voyager wont pair
The pass key is the password the bluetooth accessory has. So your car stereo manufacturer has a code that you enter on your phone, so that someone nearby with a bluetooth cell phone won't be able to hook to your stereo - it's usually in your owners manual for your stereo or bluetooth speaker system.
Most bluetooth headsets have a passcode of 0000, and it's the same for Motorola headsets, plantronics headsets etc. You may be able to lookup the passcode for your bluetooth speaker system in a manual online, if you no longer have it.
Mar 25, 2009 | LG VOYAGER VX10000 Cellular Phone
Jvc kds 24 car stereo
i have the same model and yes our radio doesnt support the bluetooth feature they did exactly as you assumed they used the same face for the model that supports that bluetooth feature.it is not even bluetooth capable which is unfortunate...if your wanting a radio/head unit what ever you want to call it i useful tip is to make sure it has the bluetooth written on the face such as this....
http://www.crutchfield.com/App/Product/Item/Photos/Default.aspx?i=158MEXBT27&g=300
keep in mind thats not always the case but in most cases it means it has built in bluetooth...but it might just mean it is "BLUETOOTH CAPABLE" meaning you can buy an adapter to make it work. just be sure to ask if it has built in blutooth. most higher end models have built in bluetooth.
Dec 11, 2008 | Car Audio & Video
Bluetooth streaming audio
i can confirm that streaming audio works with Nokia N95, well cool!
Dec 04, 2007 | JVC KD-AVX33 Car Video Player
JVC AM FM CD DET FACE CAR STEREO Logo
21 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
