Question about Health & Beauty
Wiring for pride ultra x GoGo .... under the scooter is broken wiring that appears to have once been connected to some sort of electrical plug... maybe designed to plug into an external socket... possibly a diagnostic computer.
  • Joe Sherwood May 18, 2011
    Thanks for the manual but I had already found one.
    After spending several hours last night, I discovered that the problem is not in the wiring which I was curious about. That particular wiring in not mentioned anywhere in any manual.that I can find. Evidently it is as I thought, some sort of diagnostic plug.
    so...
    The real problem..... in the manual it states
    5 beeps indicates Solenoid brake trip problem. The manual freewheel
    lever may be in the freewheel position.
    Remove the key, then push the manual
    freewheel lever to the drive
    ok....
    The incident-
    I was taking the scooter from the rear of my mini-van.
    It slipped and hit the ground, rear wheels first,. with considerable force.
    It would give me the 5 beep error message and I couldn't resolve the situation.
    I knew about the 5 beep warning, but i couldn't get it to stop the beeps by turning off the key, removing the key. resetting the brake lever to the correct position, which has always corrected the problem any time it has occurred.
    Earlier this morning, i applied a considerable force to position the lever in the correct place, and the beeping stopped and the scooter would move forward and reverse , but upon turning it off and back on the 5 beep code returned and the scooter would not move.
    Is there an adjustment that can be made to that lever/switch which evidently is not making contact correctly,. It seems to feel right and act right when the lever is moved back and forth.
    How can I can I check for adjustment or damage,
    I realize that it could also be "broken" and not repairable, in which case I would need to know if I could replace the switch part myself, assuming I could acquire one
    Please advise
    President:
  • 2,047 Answers
Usually there are tons of wires which are put in these units for diverse purposes. As you stated it could be for the diagnostic computer. Although it could also be for another purpose but most likely one or more sensors on the unit. Usually i would say if the unit does not undergo any malfunction then it is best left alone. What other symptoms does the unit show which you think is caused by the wire?
Posted on May 19, 2011
  • 823 Answers
Here is a link to the owners manual that has the schematics for your scooter. You can find what the correct wiring should look like in this book. Hope it helps?
http://www.pridemobility.com/scooters/gogoultrax.asp
Posted on May 18, 2011
How to remove seat & battery
Hi' I have a pride gogo scooter, to take the seat off just take the pin out and then push the swivel lever up and then just jiggle it and it lifts off. To remove the battery remove the canopy thats situated under the seat,then undo the strap and disconect the the front battery plug(harness) and the do the same with the rear one then your battery will lift out.
Aug 21, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Jul 25, 2014 | Pride Mobility Products GoGo Elite...
The gears are stuck
Try and gently rock your scooter backwards and forwards as you are trying to move the lever this can help. spray a little wd40 on where the lever connects to the motor. If this doesn't help then the electric brake has ceased and needs an engineer to sort.
Mar 21, 2014 | Pride Mobility Products GoGo Elite...
Wiring diagram on a gogo scooter
The wiring interconnects on these scooter are all modular and the blow up assembly diagrams are all you need to trace the wiring and replace components. Aside from a dealer log in to the manufacturer's website you can go to southwest medical's website and get all the information on the wiring and parts. Hope this helps.
SC40X Go Go Ultra Replacement Parts
Mar 01, 2014 | Pride Mobility Products GoGo Ultra X...
Have GOGO scooter, when you turn it on the alarm sounds and will not to anything, it has been fully charged.
Princess try the freewheel lever make sure its in the drive mode and turn the scooter back on Hope this helps
Mar 26, 2011 | Pride Mobility Products GoGo Ultra X...
I have bought a go go scooter which does not have a manual
evilyn Goto pridemobility.com click on scooters then find the picture for GoGo Ultra click on the picture and on that page on the right you will find owners manual click on that and download your manual Hope this helps you
Sep 19, 2010 | Activeforever Pride GoGo Ultra 4 Wheel...
My gogo-ultra will not run. it has been stored
hi,
Check the connections between the battery and motor, if the rear come apart check there connections there,
If the connection with the batteries string loaded, rough them up slighty with a wire brush but be gentle and is there freewheel lever right in position for drive.
Regards
GeWiz.
Oct 24, 2009 | Pride Mobility Products Go Go Ultra X 4...
PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Jun 10, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
130 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
