Question about Kenmore Washing Machines
My Kenmore washer will not move into the next cycle unless I manually turn it to the next cycle. This just began today. What is wrong with it?
    Sergeant:
    Champion:
  • 257 Answers
It's either the timer is faulty or the lid switch is broken. If it fills and agitates but dos not spin and drain it's the lid switch. If it spins and drains when manually advanced to that setting your timer is bad.
Posted on May 18, 2011
What could be wrong with our washer So our washer filled up with water and then will not go into the next cycle even if we try to manually do it Do you know what could be wrong
  • Does Your machine have a little switch button activated by the top door? (You can hear it click as you open and close the door.). If that switch is not working, the control click can not let the machine advance to the next step in the cycle.
  • Let US know what you find. M B
Jul 08, 2014 | Kenmore 24032\24036 Top Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Washer 110.92281100 won't stop
I purchased a new timer, installed and solved the issue.
May 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Front load washder does not go through with cylce
hello nplooj
welcome,
You said, front load washer would not continue through the cycle. For example, when I turn on the wash cycle, it will stay at that position and does not go to the next cycle. Every time I want the machine to move from one cycle to the next I have to do it manually such as from wash cycle to rinse cycle. The dial won't not turn unless I turn it manually. Please give me a suggestion of what part of the machine is not working properly. Per my understand and my friend told me, it is probably the time is not working. If that is the problem, can I replace the timer myself and how much it cost for the replacement part.
You do have an ATF6000 front load washer?This is made by Frigidaire or Electrolux
Did you get any error code?
Like an "F1" ?
Yes it can be replaced It is part of the,
Control Board,pc ,with housing $ 139.22
Here is the site with the parts.
http://www.pcappliancerepair.com/model-display.php
Let me know how you do.
Huuum,
Please remember to leave a rating!
Oct 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Front load washer doesnt switch to the next cycle.
The timer motor does not turn need to replace .
Nov 27, 2007 | Kenmore 43142 Front Load Washer
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Washing Machines Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
