Question about Video Game Consoles & Games
Player wont read disc i also cant hear the spinning motor nomore shur off while i was playing black ops online
    Problem Solver:
  • 6 Answers
This issue comes up now and again. Most commonly your lens needs to be cleaned or replaced. There are cleaning kits available at big box stores and online. Try one of those first, If that does not fix your issue the only thing you can do is set up a repair with nintendo at www.nintendo.com
Posted on May 18, 2011
I have 5 disc changer that will revolve but wont play disc just keep running.
What you hear running may be a fan, a motor that spins the CD, the motor that moves the head in & out, or the motor that turns the turntable.
I suspect on something that old, the motor that spins the CD may be worn out. Place 1 CD in position and make note of the exact position of the words on the CD, let the player go through all 5 positions and see if the CD is still in the exact position that it was when you started. If this is the problem there's usually no easy way to fix it.
If the turntable doesn't turn, then it's that motor or a possibly a belt that no longer works.
There is also the possibility that the read head is no longer moving in and out smoothly, you'll have to take the unit apart and re-grease the slides with light lithium grease.
The read head being dirty or too dusty is another possibility, but even less likely. When you get it apart, clean the read head with a cotton swab and rubbing alcohol, anything harsher might damage the components.
Oct 08, 2016 | Sony CDP-CE375 5-Disc CD Changer
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
I have C.O.D. Black Ops and i can sign into xbox live and paly any game online, but Black Ops wont!!! I get all the way to whier it searches for players but the search never ends and does not enter me into...
Check for scratches on the disc. If the disc is unscathed, then try this. If you know someone else with Black ops for 360 ask for their help. First try their copy in your 360. If theirs works it's your disc. If their disc doesn't work either, then try yours in their 360 online at their place. If it works there, then you might need to strengthen your internet connection.
Feb 04, 2011 | Microsoft XBOX 360 ARCADE Console
Can two players play call of duty black ops on Wii? can 2 players play, more specifically, Zompbies on CoD black ops on Wii (without resorting to wifi or going online)? if there is no way of two or more...
Sign into a PSN account and launch Call of Duty: Black Ops III. After reaching the Main Menu, connect a second controller. Press X on the second controller to connect the other player online. Once connected, press X again to attach the split screen player.
Oct 30, 2017 | Activision Call of Duty: Black Ops for...
Wont play
If its not a power problem, notice that the servo motor is spinning or trying to spin with a disc in the tray.
-listen carefully for a high pitch or whinning sound of the motor.
-do you have a reading on the screen? No disc or reading disc?
One of the above can be:
1- a defective laser (it wont illuminate)
2- a broken flat cable to the laser (you wont hear clicking sound when reading)
3- a bad servo motor that can not reach its speed to read the disc (has to spin at a very high speed)
Hope you can solve the problem, succes
Aug 27, 2010 | Apex Digital Televison & Video
I bought a new LG Blu-ray player at Best Buy in December of 2009. For the last couple of months (begining in May of 2010) I'be started experiencing my player not wanting to play a large majority of my...
two of the main problems associated with players are their motor's and their lens. the lens emitts a light which reads the image off the disc, if the lens is going bad then that lighting signal isnt as strong as it should b and it wont be able to read the disc. on the other hand if the motor spinning the disc is spinning to slowly or it starts but doesnt continue spinning to allow the lens to read the disc then u will experience the problems that u are facing with your player.
solution: get the whole lens motor mechanism changed.
Aug 26, 2010 | LG BD370 BLU RAY PLAYER
Turns on, but will not play or recognize DVD
The spindle motor motor is defecteive already. replace it. when the spindle motor not working. the cd wont spin, how can the optical lens read the disc when its is not spining. you need a qualified technician to fix your problem.
Jun 27, 2010 | Insignia IS-PDO40922 Portable DVD Player
Disc wont play, when starting up player sounds like its running then gives cant read disc error
it could be one of 2 things, either ur laser is on its way out or the motor in the dvd drive has run out of lubricant. the latter is quite obvious as the drive will be noisy when spinning!!!, if ur tech savvy and are capable of doing so, remove the drive from the xbox and open up the drive casing, the motor is situated under where the disc sits on the little black disc. there are 3 screws holding the motor in place, remove them and with gentle pressure pull the black section from the motor, clean thoroughly then place a couple of drops of wd40 or 3 in 1 oil onto the shaft. re-assemble and that should solve the problem..
Mar 11, 2010 | Sony PlayStation 2 (PS2) Console
When playing cd player , cd rotates angle of 5 degrees clockwise
Hi there
It is probable that you will have a faulty spindle motor if the disc wont spin up to speed. Have you been able to give the disc a kick start to get it to read. The disk also has to spin the fastest when reading the table of contents after the disc is first loaded. Sometimes when the suspension rubbers to the laser fail, the disc may also be catching on parts of the mechanism preventing it from spinning up to speed. Can you give me a little more about how the problem is occurring, particularly what noises you hear, and whether you can kick start the disc to spin. I have plenty of experience repairing these players, and am happy to answer any questions you may have about it. Cheers
regards
robotek
Dec 11, 2008 | Pioneer Audio Players & Recorders
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
Video Game Consoles & Games Logo
63 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
