Question about LG 24 in. LDS 5811 Built-in Dishwasher
LG 3 in 1 Dishwasher model LD2131SH
I have 2 problems.
One: 1 out of 10 times my LG dishwasher gives a E1 message half way through the cycle and stops. I have checked everything, but cant find anything wrong - no bent pipes or water leaking anywhere.
Two: For a year the LG dishwasher has been running very soft - wonderfull. A couple of weeks ago it started making a banging sound through the whole of the cycle. I firts thought its the centre arm banging against some plates thats to big, but that wasnt the case. It still works fine, but the noise is triving me crazy.
Do you have solutions for the 2 problems above?
Regards
Cedelle
  • 770 Answers
E1=Water inlet Error
Not reached to the normal
water level in spite
of 10 min. water supply
Causes:
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
Posted on Aug 20, 2008
E1 message on my LG Inverter Direct Drive Dishwasher
An F1 usually means a communication error between the control board/touchpad and the motor/pump assy. Could you please supply the full model # for your unit?
Mar 12, 2014 | LG Dishwashers
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
Oct 26, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
LG LD2131SH Dishwasher displays a ie error
Hi santjiesfras,
The error code your receiving is an "Inlet Error" message. This means that no water is going into the Dishwasher. Please check the following:
1) Is the tap open.
2) Is the inlet hose kinked?
3) Is your water pressure fine? Because anything less than 0.3kgf/cm(bar) is not going to work
If all of the above is fine, then take off the inlet hose of the dishwasher, and clean the filter which is between the hose and machine (small circular filter). If still not working, then you will need to replace the inlet valve. I would suggest getting a L.G service agent to do so.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Apr 13, 2011 | Dishwashers
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Sep 20, 2007 | Dishwashers
Error code E1 on LG dishwasher
I have this sometimes where E1 is reported and the pump remains on. The following voodoo has worked for me.
1) Make sure there is not a real drain problem.
2) Cancel any cycle or turn the power button off then on.
3) Run a rinse cycle (15 minutes).
4) If pump continues to run, turn off the power to the dishwasher, let stand for a minute, then repeat steps 2-3. If still not working, leave power off over night and leave the door open then try again.
In each iteration, it is important to curse your LG product and/or threaten it with replacement.
Sep 04, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
1,309 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
