Question about Canon imageRUNNER 5000 Copier
Whether Canon IR5000 printer can be a tool, through the com settings (data). how do I to connect the cable to the machine copies com IR5000.butuh lan similar devices or other connector?
  • Canon Expert
  • 1,326 Answers
If I understand what you are ask???? You need to know where the ethernet cable goes in to the copier?? The conector is above the main power switch on the right side of the copier.... The print funcation is a option with a IR-5000...... Do you have a ether net PCB installed???? If you do not, you need to get a new boot rom & more ram & the ether port and lastly, you need to have your hard drive flashed to print...... Good Luck
Posted on May 19, 2011
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
ERROR CODE EA21F7
LOTS TO CHECK
Check if the LAN cable has been correctly connected, if the SMTP server is ready for communication, if the network settings
such as sub-net mask setting are correct, or if the E-mail address of the destination is correct.
LAN cable has not been connected, or failed to communicate with
the SMTP server. You tried to transmit the document to an incorrect destination address.
A LAN cable is not connected. Check that the LAN cable is connected correctly. The network of the network multifunction
machine and the PC with the IP address of the destination mismatch.Confirm whether the network settings of the PC and the network settings of the network multi-function machine pose a
network-type problem.The network settings in the PC have
not been set correctly.Check the TCP/IP settings of the PC.
The network board of the PC with the IP address of the destination has failed. Replace the network board or the PC. Power is not being supplied to the HUB. Supply power to the HUB. A cross-type network cable is not being used for Peer-to-Peer connection.
Use a cross-type cable. The network cable is disconnected. Replace the network cable. Network load in the destination PC is
too high. Check whether a mail with large size data is received in the destination PC, or a large file is downloaded from the Web.
There is too much transmission data. If the scan resolution is set high, scan fewer pages. The access is limited by the firewall
(Windows Firewall) of the network connection in the PC.
Consult with the network administrator, and change the firewall (Windows Firewall) settings of the network connection.
Dec 10, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Hi dear the connection between computer and canon image runner 3300 xerox mechine is proper. but it is not printing any documents the system is showing document failed to print. please help me
are u connect through lan cable ?
machine is showing data is receving mean there is green light blink when data is receving
if not blinking
then there is stuff with ur IP adress
just try to ping ur machine IP
if it replay then ok
other wise check ur settings
Aug 06, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
How to reinstall canon IR5000
I have canon IR5000 machine. The data on the HD is corupted how do I reinstall the system software
Jan 24, 2011 | Canon iR5000-6000-L1 PS Ver 1.0
If ir5000 parralel port can be use for printing from computer
If it has parallel port you must have connected it to your pc and would be using to give print cmd through pc. If not then you require installation cd to install printer driver. and enable file and printing sharing in your lan and you can give print cmd from any pc of your lan. What is your exact problem kindly let me know in detail so i can solve it.
Jun 14, 2009 | Canon imageRUNNER 5000 Copier
Ir5000
sst itu Service Support Tool kl sm apa ya? kalo mau sst nih linkya
http://techchatter.servehttp.com/yabbse/index.php?topic=356.0
n nih frmware ir 5000-6000
http://rs147.rapidshare.com/files/197499533/__304_R5000-6000.rar
Feb 01, 2009 | Canon imageRUNNER 5000 Copier
Hardisk ir5000/ir5000i
You need to have the hard drive "Flashed" with the correct software. They come from Canon blank, you need to find a tech to flash the HD for you. If your question is if one would work in the other copier, the aswer is yes, but you need to have the printting software on that HD if you want it to print.... Good Luck.... Just for your info. you may want to ask your question in English if you want a respones from one of the techs.
Dec 30, 2008 | Canon imageRUNNER 5000 Copier
How to replace HDD IR5000??
how to clear hard disk IR 5000 and where i can find hard disk software
Dec 20, 2008 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 5000 Copier Logo
135 people viewed this question
old marine
old marine
