Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
Headset indicates fully charged (green light) After unplugging green light goes out & will not turn on, as if no power.
  • 6,771 Answers
The rechargeable battery is bad and needs to be replaced.
Posted on May 18, 2011
  • 31 Answers
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
Oct 20, 2014 | Nokia Bh-503 Bh503 Bluetooth Stereo...
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
Motorola H710 Bluetooth Headset will not turn on!
I have the exact same problem with my Motorola H710 Bluetooth Headset. When I charge the headset a green light is displayed. After the charge is complete I unplug the headset and NO light is displayed. I flip open the boom and NO light is displayed. I hold the call button for 10 secs or 10 mins or 10 hours and NO light is displayed. There is suppose to be a blue light displayed to indicate that the headset is ON. Since there is NO light displaying that means the headset is OFF. So my headset DOES NOT TURN ON! I did my research no where online can anyone give a solution. All the above solutions given does not help because the blue light DOES NOT turn on. No user guide or customer service rep or tech support can help that is what I found out. So I guess I will toss my headset in the garbage!
Nov 26, 2011 | Motorola Mobility H710 Bluetooth Headset
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Want turn on when charging green & red light flashes
Normally if you have a VXi, B250-XT on its charger and you are seeing both a Green and Red light the headset is changin over from charging to fully charged. The headset is designed to be able to use while it is on the charger however once you place it on the charger you must turn it on to reconnect to your phone before you can do this. Put the headset on and press the Multifunction Button for 2 to 3 seconds, you should hear two rising tones and the headset should reconnect with your phone. Note* your phone may require you to accept the connection request.
If the headset will not turn on either on or off the charger I recommend calling VXi at 800-742-8588 for warranty repair information. A headset that will not turn on indicates the unit is having an issue with one of its control circuits.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
I have a h700 bluethooth and dont have a manual. what color should the light be when connecting to the phone, in use, and charging.
The indicator turns red when charging and turns green when fully charged. The headset will flash in purple when it is in discovery mode (mode where it is looking for a device to be paired with it). If it has already been paired with a device it is blue and then flashes blue when it is paired. The link for the manual is below. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Jul 23, 2011 | Motorola Mobility H700 Wireless Headset
H700 Motorola BT earpeice, no indicator lights aside from a green
Same thing happened to me. I call the support center and if you bought it from a 3rd party, it is probably a software problem. See if you can get a new one or buy it elsewhere.
May 19, 2010 | Motorola Mobility H700 Wireless Headset
H700 Motorola Bluetooth Headset
Make sure that any devices previously paired
with the headset are turned off. If the indicator
light is flashing in blue, turn off the other device,
then close and reopen the headset boom. The
indicator light becomes steadily lit in purple
indicating the headset is now in pairing mode.
Jan 03, 2010 | Motorola Mobility H700 Wireless Headset
When plugged in, green light comes on immeadiatly. Light goes off when unplugged and will not come on.
The green light indicates that the unit is already adequetly charged. If KNOW that it is NOT charged, but are getting a green light anyway, then the unit may need to be replaced.
Aug 20, 2009 | Motorola Mobility H700 Wireless Headset
Green light stays on....headset not turning on
I have had no trouble with mine (3+ months of good use) until today. Same problem you had - green light won't go out, unit won't turn on. Jonsumer's solution got me to thinking, and this worked for me:
1. plug the charger into the wall.
2. plug the headset into the charger.
3. unplug the headset from the wall.
Plugging & unplugging the headset to charger multiple times had NO effect. It was only when I plugged it into the charger and unplugged the charger from the wall that the green light turned off and the headset began to work normally.
Jan 06, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
531 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
