Question about Garden
I have an iwata hp-c plus. Air is continually coming out the nozzle of the gun even when I do not have the trigger pulled back. I have pulled the gun apart, cleaned it well and put it back together, buts its still doing the same thing. It actually is in great working order. Its just constantly blowing air. Can you help me?
    Problem Solver:
  • 6 Answers
Since the engine is running it needs to have an exhaust port, If it is in fine working order I would assume that it is simply the exhaust from the chainsaw. even with the trigger not pulled you are still idling causing exhaust build up. I would need more information to be able to delve deeper.
Posted on May 18, 2011
Leaking air behind the trigger
If you take the gun apart you will see a small o-ring on the trigger side that needs replacement and possibly the spring on the media adjuster side as well
Feb 18, 2013 | ANEST IWATA IWA5810 LS400-1302 Spray Gun...
Air bubbling up in cup when air trigger is pulled this is a gravity fed hvlp spray gun
it means the air holes in the nozzle are blocked the air couldn't get out in the front so instead it went back to the cup makes it bubble
Aug 20, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
After switching from a 1.2tip to a 1.4 tip when i
adjust the knob that holds the needle inside the gun
Mar 17, 2010 | Dmm Iwata LPH400 LVB Gravity Fed Spray...
Trigger pull is not as far as older model
some models have less trigger movement than others.
at the back of the gun you have two adjusting knobs the lower one controls the trigger movement, which controls the fluid flow from the nozzle.
Oct 06, 2009 | DeVilbiss PLUS? Pressure Feed Spray Gun #...
No pressure
It is probably air locked....Here's what you need to do. Connect the garden hose, and HP hose, but not the gun. Turn on the water, and let it run while you make sure that there are no high points in the garden hose that can trap air....Work the hose so that any air is displaced through the pressure washer. Continue in this manner through the HP hose. Shut off the water and connect the gun. Turn the hose back on, and operate the gun for several minutes, pulling the trigger and releasing. This alternately allows the water pressure to build up on house pressure and then to depressure, pulling residual air from the system. Release the trigger, and start the machine. Usually, this is enough to get full washing pressure. If it is very difficult to start, you can hold the trigger down on the gun and pull the start cord at the same time. Holding the trigger down acts as an unloader, making the starting easier.
Hope that this helps, --W/D-- please feel free to rate this solution! Thanx!
Jul 31, 2009 | Garden
Iwata w400 air leak behind trigger problem
Have you traced the exact spot of the leak?
I will assume you have not. the reason it's important is because if there is a crack in the o-ring seat there is nothing you can do. So trace the leak. Try a small amount of auto air conditioner leak detector or something similar even ink from an ink pen will work. Place it in the air inlet, hook up your air line and trigger your gun for a 10 to 15 seconds. disassemble your trigger and see if you can locate the offending spot. Though this method has worked for me in the past, it's not something I would normally recommend. However the gun you have is to expensive to just write off.
The alternative is to contact Iwata and seek help.
Good luck.
Jun 23, 2009 | RTO Iwata 1.4 W-400 Gravity Feed Spray...
My iwata hpc is pushing air back through the paint cup
Try replacing cup gasket first then clean all inlets and outlets completely, check that all valves operate properally, and all seals and o-rings are in good condition. Clean and lubricate adjustment fluid valve.
Jun 16, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Spray gun leak
go to iwata site they will help
Apr 27, 2009 | Dmm Iwata LPH400 LVB Gravity Fed Spray...
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
