Question about Tripp Lite Lite APS INT 2012 UPS System
I ask my asistant to open my aps 2012 trip lite inverter and he did but he also disconnected all the cables from the board and i dont know how to reconnect them. can u get me a schemathic diagram for it? or some thing that can guide me to reconnect the cables?
  • superior1 May 20, 2011
    I SAID HE OPEN THE INVERTER AND DISCONNECT ALL THE CABLES AND I DONT KNOW HOW TO RECONNECT THE CABLES. IM NOT TAlKING ABOUT THE BATTERY AND AC CONNECTION OUTSIDE THE INVERTER.PLEASE!
  • 794 Answers
Hi superior1,
I have provided the owner's manual for you here that you can download. On page 11 you can check out the hard wire connection.
Hope it helps.
Thank you for using FixYa.
Posted on May 18, 2011
LG 47LG50 has no picture.
T'Con board fault. Check and replace it. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 02, 2017 | LG 47LG50 47LG50 47-inch 1080p LCD HDTV...
I don't know which is the dome light connector in my 2012 Suzuki Swift. I need it to hook up footwell LEDs.
alldata.com
its all there, log in and look
2012 is newer car, you want to hack a newer car?
some sources do not fully support newer cars.
(show empty, at alldata. or mitchells)
that means that newer car is not published yet, there.
so you get to buy the 2012 real FSM from Suzuki.
oops even pitstop dont have it
https://suzukipitstopplus.com/Category/3-suzuki-service-manuals.aspx
so a trip to Suzuki real, call them and ask for a real FSM
good luck with Chapter 11 Suzuki, here in USA and Canada.
id sell it.
Mar 12, 2014 | Suzuki Cars & Trucks
Lcd screen works, but will not lite up
the backlight has gone bad, and you CAN replace a backlight but it's not cost effective. i'd replace the screen.
May 03, 2012 | Toshiba Satellite A105 Notebook
How do I fix the constant flickering of the screen?
Take the lcd assembly apart, and disconnect and reconnect the ribbon cable on the back of the lcd. Also disconnect and reconnect the other end of that cable. If that doesn't fix it, disconnect and reconnect both cables that go to the inverter board (it's the small circuit board inside the lcd assembly- example in picture below). If still no good, then you probably need a new inverter board. Call HP and get a phone number for one of their parts suppliers. Inverter boards are cheap ($10-$20). Even if it doesn't fix it, it doesn't cost much to try. If still no good, then take it to a service shop.
Hope this helps!
Joe
Mar 22, 2012 | HEWLETT-PACKARD HP Pavilion G61b70us...
I have a 26' Toshiba LCD TV Model: 26WL65G. When I plug in and turn it on it seems to start normally, but when screen turns on blue screen appears as normal and it goes back to stand-by mode...
Note that if it is a backlight inverter board problem you will still have sound. SInce you have no sound I would suspect a power supply or main A/B board malfunction. Do you know how to use a multimeter?
Dec 11, 2011 | Televison & Video
APS 912 worked for about 6mo - 1yr. Used with a
Sorry this is what the industry refers to as a throw away.
Sep 12, 2011 | Tripp Lite Lite APS INT 912 UPS System
Freedom 20 stopped working after ac breaker tripped
How do you get the PCB out all the 4 screws are out and clips are pushed off the pcb contacts on the sides. Unscrewed the antenna, but not the soldered in bulk antenna mount. I is still locked in somehow? how do I get the board out to look at the keypad buttons so I can see if threre is a bad contact?
Sep 10, 2009 | Xantrex Technology Heart Freedom 20 12...
I have just replaced toner however an AP sign appears now. I have added paper to the tray (as i have no manual I dont know what AP is asking me to do) Can you please help
hi
AP means that the toner in the hopper got so low that you will need to cycle the toner several times.
to do this you will need to open and close the front cover between each cycle to ensure enough toner is in the system
Aug 03, 2009 | Kyocera KM-1505 Copier
Dell W1700 picture went out. Still have audio.
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
Nov 29, 2008 | Dell W1700 17 in. HD-Ready LCD Television
ASUS P5N32-SLI Premium/WiFi-AP
they dont sell them u need clal asus .com ask f they have one 5 10 bucks ok or else just dont use it alsoways install i o shild 1st then mobo
Oct 13, 2008 | ASUS AI Lifestyle P5N32-SLI...
Tripp Lite Lite APS INT 2012 UPS System Logo
44 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
