Question about Samsung SC-D363 Mini DV Digital Camcorder
I need the pics from my digital cam - how do I get the pics from my digital cam to my computer
Whenever i use the usb cable to put photo on my computer i lost same of the picture ,when i am looking through the picture between every 3 photo a''! picture error'' come up.
There must be a software of some kind on your PC that modifies those pics in some way when you connect the cam (or maybe u edit the pictures :) ). If any picture on the cam is edited and saved, the cam will not detect those pics again.
Mar 22, 2011 | Olympus FE-26 Digital Camera
I am trying to download pics to computer i have already downloded software etc and have successfully downloaded other pics from cam since i have added a memory card when I plug cable to download into...
Blinking light means your computer still in process reading your data from memory card. Higher capacity of memory card would make the computer need longer time to read it. Just be patient and don't unplug the USB cable.
If you think its too long, then you can unplug the cable data, put off the memory card and open in via card reader so you can download your pictures to PC.
If useful, RATE please !
Jan 18, 2011 | Kodak Easyshare C182 12MP Digital Camera
Pics. wont upload to computer no disc
if your camera has a switch for display or camera modes, then you may have to switch it to display mode to view the pics on your computer with the usb cable. When the switch is in the camera mode it will usually try to install it as a web cam and won't show any pics.
Sep 26, 2010 | VistaQuest VQ-5115 Digital Camera
No icon is coming up when the digital photo keychain is connected to the computer via the USB. the keychain is charged, the screen is displaying the generic photo already on it but, no icon and no transfer...
When the cam is connected to the computer no pics will show on the LCD. While charging through the USB the cam. will not be able to transferre pics at the same time.
The cam either charges or transferres.
Oct 02, 2009 | Cameras
How do I get software to view my pics on my computer from my camera? moultrie model # DGW 100
PLUG CAM TO PC ...TURN ON CAM found new hardward wiz comes up choose pick driver from list, choose generic on left/imaging device on right;find new drive under"my computer"double click folders and sub-folders until pics show up...enjoy
Ron L
Sep 28, 2009 | Moultrie MFH-DGS-100 Digital Camera
Pic are not copy computer to camera?
If you are not able to transfer data from comp to card. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... But some pics have higher resolution than your cam,so pics may not be visible on cam's LCD OR it may show pics are not compatible Hope this helps you out.. :)
Mar 10, 2009 | Canon IXUS 80 IS Digital Camera
UNABLE TO VIEW PICTURES
no disc for these cams...should be able to view pics straight from SD card thru a card reader to pc...(may have to go thru START..MY COMPUTER...LOCATE DRIVE CARD READER IS DESIGNATED AS....
also should be able to view pics on tv thru video cable attached to cam.
Jan 24, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
4100 vivitar has pics and sd card, will not load pics on pc.
Battery Drain is probably the problem
Best bet?
But a Card reader.
And if you have camera software loaded -unload it
Windows does it better.
Nov 09, 2008 | Vivitar ViviCam 4100 Digital Camera
Problem with my cam
you do not need software for this or any other camera Windows XP can cope very well on its own. Plug in the camera. make sure it is switched on and set to upload. Windows will put up the picture and scan Wizard and ask what you want to do with the images Take it from there
Apr 09, 2007 | Olympus FE-110 Digital Camera
I canĀ“t unloaded the photos from my PC-Cam
I had the same problem with my PC-CAM 600. I went to the OEM site. Downloaded drivers and re-installed them. Try and see if solves your problem.
Sep 12, 2005 | Creative Labs PC-Cam 600 Digital Camera
Samsung SC-D363 Mini DV Digital Camcorder Logo
12 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
