Question about Oral B ??? Oral b Professional Care Toothbrush Smartseries 5000
My oral b smartseries 5000 triangle red light is continously on. It never shuts off how do I fix this. What is the problem
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
My 5000 series tooth brush will not charge i tried it with a few adapters and still no result could it be the base or plug that is malfuntioning , i am an electrician and there is power in the socket so...
I have bought many rechargeable devices and about 4-5% of them have bad Chinese batteries in them. I also have converted nearly all battery operated items to rechargeables and these often have spotty performance with several out of a couple of dozen not worth keeping. You might try running the batteries down as far as possible and then trying to recharge. If they are NiCads, they may have developed 'memory,' a known weakness of that type and NiMh batteries in particular seem to need several charge/discharge cycles before they will come somewhat up to their rated capacities.
Mar 24, 2011 | Oral B ??? Oral b Professional Care...
What is mean this my uterus is normal in size and contour. No filling defect / anomaly is seen
Hi, you are healthy and you have nothing to worry with your uterus based on oral B check.
Jan 17, 2011 | Oral B ??? Oral b Professional Care...
The red triangle warning light just came on. What does it mean?
All it means is 5000 miles have passed since the oil change reminder was reset. You can reset it your self. Look in the Camry Hyrbid Owners Manual on Page 148 for the Resetting the engine oil maintenance data procedure. Make sure you have the A trip odometer showing when you follow along.
Oct 05, 2010 | 2009 Toyota Camry Hybrid
Red triangle with exclamtion point continously on.
Is a safety warning lamp.You need to go a saab dealer!
Mar 03, 2009 | 1999 Saab 9-5
Red light came on and air conditioner will not turn back on
I had a similar problem on a B&Q air conditioner and all it needed was the drain plug removing and the water draining out - then it started back up straight away
Jan 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Turning on shuts off red light starts blinking
Hi
You have defective Oscillation Circuit maybe you have leak small parts like capacitors and resistors. and also the HOT Area.
Thanks!
Dec 04, 2008 | Televison & Video
Oral B ??? Oral b Professional Care Toothbrush Smartseries 5000 Logo
198 people viewed this question
Top Oral B Health & Beauty Experts
Jonathon summesfield
bayou sam
Are you an Oral B Health and Beauty Expert? Answer questions, earn points and help others
