Question about Dryers
It runs but no heat at any setting. - Dryers
  • Dryers Master
  • 7,482 Answers
Hi khowtopat...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 18, 2011
Why does my PTHP. shut off and switch to electric resistance heat?
im guessing its there way of defrosting the coils , as with this type (small) its tough to defrost the coils in an efficient way , hp runs normal to within one or two degrees of setpoint , hp shuts off or reverses in low speed , back up heat comes on to complete the room heat and to generate the heat needed to defrost the coils , entire unit shuts off when set point is reached , reversing valves set for heat and wait till next cycle
now mine does something slightly different : it runs for fifteen minutes and if set point is not reached it switches to back up and reverses the coils ,leaves compressor on (low speed) , this heats the coils up and defrosts the outdoor unit , and if it runs long enough twenty minutes total time , it goes back to normal and aux heat shuts off . this drives me insane thinking how much im spending on heating the outside !! but im sure its needed to prevent ice build up on outdoor coils ,and I sure don't want that cracking with ice formations
Jan 30, 2016 | Amana PTH153B50AJ Heat Pump Air...
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
Honeywell th6110d1005
Make sure it's in auto, not manual.
Nov 28, 2013 | Heating & Cooling
Cooling fans always on in any heat setting
You are right,seems like it must be the control switch to me
Nov 17, 2013 | 1999 Ford Taurus
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
I have an issue with my goodman splitt system. It is a 2 ton unit. 2 days ago the heat would come on and when the temp came up to my setting the heat kicked off, but the blower kept running. it does not...
what is the fan setting at? If its set to on then it will rum all the time if its set to auto then it should only run in heating or cooling mode? It is located on your tstat
Dec 30, 2010 | Goodman Heating & Cooling
I have air coming from the vents but no heat. The furnace is 23 years old and I've never replaced anything in the unit. Best guess? GE Intertherm. thanks
If the thermostat is set on Fan and not Auto the fan will continue to run. If the fan control is bad or is set at too low of a setting, it will blow cold air after the furnace has shut off. From what I guess of your explanation, your furnace is not producing any heat and the room air blower runs blowing cold air. You may have two issues happening. Make sure your thermostat is calling for heat by setting it to a high setting. Inspect the thermostat to see if it is set at Auto. Go to the heating system and inspect it to see if it is heating. If you can't view any flames carefully touch the exhaust pipe and see if it is hot. If not, you have a no-heat condition. A 23 year old furnace may need some TLC so call a technician you trust. He/she may need to replace the ignitor or thermocouple to get it going. They will also check out why your fan is running when it should not.
Nov 02, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Heater running continuously
Sounds like you have a problem with your heat pump. Your aux heat is a electric coil. how old is the unit when was the last time it was serviced? How cold is it out side?
Jan 15, 2009 | Honeywell Programmable Thermostat Heater
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
