Question about Garden
I need to check the fuel filter on my victa tornado whipper snipper (2 stroke) but don't know where it is! I'd like a diagram, it's no use talking about 'fuel manifolds' or whatever because I don't know what they are. It's almost brand new, worked for awhile but I suspect I've contaminated the fuel. It occasionally starts but stalls almost immediately, then won't start at all. Cheers.
    Sergeant:
  • 170 Answers
The fuel filter is in the gas tank on the big fuel line. You can use a piece of wire with a small hook to pull the line and filter to the tank opening. These filters are available from small engine repair shops.
Posted on Jul 17, 2017
  • 4 Answers
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Posted on Jul 16, 2009
  • 491 Answers
SOURCE: Craftmen tractor w/ Kohler engine stalls out continually
Sounds too lean.
Can you cover the air intake with your hand 90% or use the choke a bit and then load the engine to see if it runs better?
If you ever find a carb with manual high and low mixture adjustments that will fit yours......put it on and keep it on.
You can usually get then from older tractors.
Posted on Aug 25, 2009
mowerman1857
  • 389 Answers
SOURCE: Husqvarna YTH2348 stalls after 20mins
First thing to do is check and repair charging system. They are/could be related problems in that there is an electric fuel shut off solenoid on the carburetor and if the battery is going dead, it could be cutting off the fuel flow. I wouldn't worry about the spark plug or cleaning the carburetor just yet.
Put a meter on the battery terminals, run the engine at full speed and check the voltage, If you are not getting around 13,5 volts going back to the battery, repair/replace the charging system. If it is less than 2 years old, it should still be under warranty so you might want to check with your dealer. I am guessing that it is a B&S 23 HP and replacing the alternator can be expensive and time consuming
Posted on Sep 20, 2009
  • 16 Answers
SOURCE: i am after a victa mower 2 stroke repair manual
I have a victa workshop manual covering some of the older models which i would be willing to copy the relevent pagesfor you. or might be able to give you soom tips, what model do you have and can you discribe the carburettor, soom victa's use a very odd carb made of plastic
Posted on Nov 28, 2009
SOURCE: Talon Whipper Snipper won't start suspect fuel not
I have the same problem. The plastic primer has broken into pieces. i have emailed the Talon help desk - 'customer.service@husqvarna.com.au' but no reply as yet
Posted on Jan 21, 2010
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
What is the ratio for oil to petrol for mculloch whipper snippers
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Jan 24, 2012 | Garden
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
My 2 stroke whipper snipper won't start
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
Feb 09, 2010 | Ryobi Garden
My fs 45 whipper snipper is starting but running
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
