Question about RCA D52W19 52" Rear Projection Television
I HAVE A RCA D52W23. YOU TURN IT ON, LIGHT ON FRONT GOES ON THEN A CRACKEL SOUND THEN I TURNS OFF. NO PICTURE OR SOUND.
  • RCA Master
  • 8,617 Answers
Replace the deflection board. you can get one from www.tvrepairworld.com
Posted on May 20, 2011
RCA model D52w23- Power light comes on for about 10 seconds then goes off. No picture, no sound. Power supply? Thanks. Jeff
I'd check the lamp first. No apparent reason to suspect the power supply, unless you didn't mention other symptoms
Apr 21, 2010 | RCA D52W19 52" Rear Projection Television
I accidently tripped into tv, there is no damage but now I only have sound and no picture
If you can look into the back of your television and cherck to see if the lamp turns on or not.If you dont see the light from the lamp its possible the lamp was damaged.
Apr 14, 2010 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W23 won't turn on
The set is in shut down mode due to a fault detected in power supply/vertical or horizontal deflection circuits.
The common problems with this model that will cause the symptom you describe are bad power supply capacitors, bad flyback, bad HV cap in horizontal output circuit and cold solders especially under flyback area.
These are only the most common problems and it could be any number of other faults.
If you have electronic (TV) repair experience check the items mentioned, otherwise it's best to seek a qualified RCA tech for an estimate/service call.
Reply to this post if you need more advice.
Dec 08, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 HDTV; WHEN WE TURN T.V. ON THE GREEN
most likely its the smsp /deflection board for the shut down
there are some caps in the power supply cp 140 cp120 cp114 look at them and see if there puffed up
they will need to be replaced
this could also be a flyback transformer that has failed or a ribbon connector
this where you will have to look for caps first the trouble shoot through it
then you you can addresse the cmp1 issue but id guess thats the ribbon connector causing that one
Nov 01, 2009 | RCA D52W23 52" HDTV CRT TV
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
No power no picture
power supply is bad.. also you need to check your convergance.
Aug 29, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W19 52" Rear Projection Television Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
