Question about Panasonic KX-NT265 Corded Phone
KX-NT265 connected to power and ethernet. Sees the home network, even displays their local time (different time zone than physical location of phone). Can make calls out and use intercom but there is no sound.
4 Suggested Answers
SOURCE: panasonic kx tg7200fx and kx tg 1100 compatible for use in intercom
A few days ago I bought Panasonic KX TG1100 - but the base unit does not ring - only the handset!
Can I do anything about it?
Posted on Nov 20, 2008
cnavarro
  • 2460 Answers
SOURCE: panasonic kx-t7330 suddenly cannot use intercom and phone calls
I'm guessing the phone is 8 years old and you spilled something into the keystrip.
Start by unplugging it to see if it resets. Then, look for a mechanical failure (sticky buttons, broken buttons, etc.). Some alcohol and a Q-Tip will clean the buttons, or carefully take the phone apart and wash out the housing.
Last, but not least, any of the new 7730/31/35/36 phones will replace that set.
Carl
Posted on Feb 24, 2009
  • 3 Answers
SOURCE: panasonic kx-nt265 npn tunnel, can ping ip
Is the 265 connected via a TDA on the old IP ext card or the newer NCP or TDE if its on the TDE or NCP check the phones software may need to be upgraded, thats the only problem I have ever had with the KX-NT265 I now only use the newer KX-NT321 or NT343,346 etc
Posted on Jan 14, 2011
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((ยท)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Connected to wifi but no internet connection
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
Oct 24, 2012 | Cisco Linksys WRT54GX4 WirelessG Broadband...
My computer can't connect to the internet and i don't know if I lost a driver or I need a new ethernet card?
Hi, to check if your ethernet card is working, follow this instruction to check the presence of your lan card driver.,
For wired/wireless connection,
1. on your desktop right click my computer/properties/hardware/device manager
2. in device manager locate the network adapters, click + sign to expand the content. in your network adapters folder there should be the list of installed driver with no X sign or exclamation mark which means it is installed but disable. If disable, right click the icon and tick the enable option. The presence of the driver is the same with both wireless and wired connection.
The other one is, right click the Network Neighborhood icon on the desktop and select properties, inside the properties it will display, Local Area connection or wireless connection, the one your were choosing must have an status of connected,an icon with two small monitors cascading.
If no drivers installed, Install the driver, if there is hereunder is the next isolation.
The other thing also is to check your connectivity, go to your command prompt and at your c:\ prompt type c:\ipconfig /all then enter, it will display your IP address and gateway.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connecti
on
Physical Address. . . . . . . . . : 00-01-E7-6C34-11
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.253.111
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.253.253
DNS Servers . . . . . . . . . . . : 192.168.253.253
To check if your have internet connectivity type in your c:\ prompt
c:\ping ip address of your gateway {sample c:\>ping 192.168.253.253 then enter, it will prompt like this if connected
C:\>ping 192.168.253.253 -t
Pinging 192.168.253.253 with 32 bytes of data:
Reply from 192.168.253.253: bytes=32 time<1ms TTL=254
Reply from 192.168.253.253: bytes=32 time=1ms TTL=254
if no connection it will display.
Request time out.
Jun 27, 2011 | Dell Dimension 1100 PC Desktop
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
How does a router and a splitter looks like and how as well they differ?
A router is a more sophisticated network device than either a switch or a hub. Like hubs and switches, network routers are typically small, box-like pieces of equipment that multiple computers can connect to. Each features a number of "ports" the front or back that provide the connection points for these computers, a connection for electric power, and a number of LED lights to display device status. While routers, hubs and switches all share similiar physical appearance, routers differ substantially in their inner workings.
Splitter is nothing but a Switch.
Switches may operate at one or more OSI layers, including physical, data link, network, or transport (i.e., end-to-end). A device that operates simultaneously at more than one of these layers is known as a multilayer switch.
In switches intended for commercial use, built-in or modular interfaces make it possible to connect different types of networks, including Ethernet, Fibre Channel, ATM, ITU-T G.hn and 802.11. This connectivity can be at any of the layers mentioned. While Layer 2 functionality is adequate for bandwidth-shifting within one technology, interconnecting technologies such as Ethernet and token ring are easier at Layer 3.
Interconnection of different Layer 3 networks is done by routers. If there are any features that characterize "Layer-3 switches" as opposed to general-purpose routers, it tends to be that they are optimized, in larger switches, for high-density Ethernet connectivity.
Feb 07, 2011 | D-Link AirPlus DI-524 Wireless Router
Panasonic kx-nt265 npn tunnel, can ping ip
Mar 03, 2010 | Panasonic IP TELEPHONE
Ethernet on DELL 4550 with TP-link doesn't work
pinging 127.0.0.1 just tells you that your network card is operational and reacheable by your system.
I have a couple of suggestions - check them out and let me know what you found out.
  • Go to Network Connections / Local Area Connection / General Tab / Properties / Internet Protocol (TCPIP) (from the list)/ Properties. Are all settings set to "Obtain automatacally..."?
  • Is your operating system Windows XP Home or Professional (with Service Pack 2 installed)?
  • Have you installed the AirPort Utility software that came on the CD? (Check Start > All Programs > AirPort)
  • You have to have the software installed in order to setup the router.
  • What is your internet connection: Cable or DSL?
  • Take a look at this document "Designing AirPort Networks" which is also on the CD that came with the device. If you don't have it, here is the download (link). Go to page 25 and follow the instructions for PPPoE (if you have DSL service) or DHCP (if you have cable service).
Let me know how that works for you and if you have any more questions, just come back here and leave a comment - I'm happy to look further into that if this did not work for you.
May 27, 2009 | Dell Dimension 4600 PC Desktop
IPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
Dec 12, 2007 | Apple iPhone Smartphone
Panasonic KX-NT265 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
