We have a Rheem Pool heater 009977 model #P-M406A-EP-C, we can not get it to light. We turn it on it tries to light (goes to CFH a couple of times) then ROL comes up with Service flashing in the upper right corner. It's for a spa and is a couple of years old.
co7196
  • 3433 Answers
SOURCE: Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Posted on Jun 01, 2009
james3751
  • 614 Answers
SOURCE: Rheem Raypak Pool Heater P-M406A-EN-C Manual
Go to www.raypac.com you can download manual from that site. Rus
Posted on Mar 17, 2010
  • 760 Answers
SOURCE: I just purchased a home
They have good listings on their web site.
http://www.rheem.com/product.aspx?id=8B064EC5-B708-4821-9F2B-DEF3A2243F90
That link should be to your model. When you click on the link for your manual (installation instructions)l, if it doesn't download. Right click on the link, and select download
So what is the problem?
Posted on Aug 12, 2010
macdirk
  • 116 Answers
SOURCE: I have a Rheem raypack pool and spa heater. I have
Error Code ROL is "HEAT ROLL-OUT SAFETY SWITCH OPEN". The heater is equipped with a cutoff device to prevent flame roll-out in the event the heat exchanger becomes blocked. This is either a "manual reset", or "Single-use" type fusible link/thermal fuse, that must be replaced or reset after any over temperature conditions have been fixed. Excessive restriction in the heat exchanger flue passage may cause the switch to disable the heater. I don't know your exact model so I'm just generalizing. If you reset or replace the switch, and it trips/burns out again, then you need to address what is causing it. make sure the heater is cleaned out well and no debris is blocking the flue. I fthis doesn't help you can always try calling Raypak Service department at (805) 278-5300.
Posted on Sep 20, 2010
adamh294
  • 310 Answers
SOURCE: Rheem 266K to 399K BTU Swimming Pool Natural Gas
ROL code means Rollout.
This heater used a one time use switch in the cabinet on the left hand side.
The switch will look like a ceramic oval disk about 1.5" in diameter. It will have two wires coming from it.
This switch is one time use because it mean your heater is getting a bad burn. This could be happening due to:
1. High wind situation (could be random)
2. Incorrect gas supply
3. Incorrect venting (if indoor)
4. Obstruction on top of the burner tray.
There was a recall on the refractory kit with some of these models, causing the fire walls to crack off and fall on top of the burner tray. Thus causing the flames to rise too high inside the cabinet and therefor trip the rollout switch. The timeline for the recall matches your heaters date.
E-mail me if you need more help.
ahudson43@yahoo.com
Posted on Dec 29, 2010
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
Rheem pool heater, M406A, display has failed. It is only partially readable and has a dark spot inside it. Is the replacement part the PC board/controller? Is this a job for a savvy homeowner or call
The display is part of the pc board and it is very easy to replace. It is also fairly expensive part just to read the temp(around $400.00). If the heater works fine except for the display you can get by. Hit the up arrow button about thirty times this will ensure you have max'ed out the temperature at 104 degrees. From there with the down arrow you can count down to the desired temp. The mode button should work normally to turn the heater on or off as desired. This is obviously not the repair but it will buy time until you are prepared to replace it or have a technician out for another call.
Apr 12, 2014 | Rheem Pool & Spa
Rheem M406A, HL2 fault
high limit bad check gas pressure over heated
Oct 16, 2011 | Rheem M406A 399K BTU Cupro Nickel Pool or...
I just purchased a home that has a Rheem Digital Gas Heater for my pool / spa (Model P-M406A-EN-C) 399k BTU. I cannot find a manual on the Rheem company website. Any idea how I can obtain one?
Aug 12, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
I have a Rheem Raypack pool heater and cannot locate my manual. The model is pr266a-ep-c. Is there a way to get the manual?
If you run a search for Rheem or RayPak the site should bring you to a menu that will have most manuals.
www.raypak.com/uploads/6000.52AG.pdf
This link may help but I think it goes to an older heater, but it will give you a start.
May 08, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
