Question about Magellan Maestro 3200 GPS
My Magellan Maestro 3210 powers up with the blue screen, but then the screen goes blank. I've tried several reset methods without success. When I press reset and the power button I get a white screen with several lines of information and reboot data and I can scroll through them with the reset button, but the unit still won't go past the blank screen. What can I do? It's about 2 years old and has worked well until now. thanks for any help. FSR
jazzyboy11
  • 728 Answers
SOURCE: i need instructions on magellan maestro 3210 Ref 447
Her you go: http://www.magellangps.com/assets/manuals/maestro_3210_manual_en.pdf
Hope this is the manual that you were looking for and hope this helps!
Posted on Apr 07, 2009
  • 3 Answers
SOURCE: magellan 4250 blue screen, not able to reset
This may mean that the GPS was formatted and there is no data on it. So basically, you can't do anything with it because all the maps and software were deleted.
Posted on Jun 22, 2009
  • 1111 Answers
SOURCE: magellan maestro 3100 frozen on blue screen tried
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Posted on Jul 19, 2009
  • 1111 Answers
SOURCE: Hi My Magellan Maestro powers up with the Magellan
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Posted on Aug 03, 2009
SOURCE: Start Up acreen frozen after completed the bar.
I have a 4250 with the same problem. And since it is froze I am unable to connect through usb and reinstall update.
Posted on Oct 05, 2009
Once I updated my Magellan Maestro 4250 the beginning Magellan screen comes on & the bar at the bottom advances like its loading then it stops and freezes. I've tried reseting it without success...
Try re booting, turn off like normal, then when you go to turn it on, hold power button down all the way through the start up, and 15 seconds more than release the on button, now it's rebooted, see if that helps, let me know.
Jun 11, 2011 | Magellan Maestro 4250 GPS
Tip
Could not get this to work with a Magellan Maestro 3210 where the 2008-09 map...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 17, 2009 | Garmin StreetPilot C330 GPS Receiver
Have a 4040 maestro magellan will not get off the magellan screen
if this just happened, and you have not tried to update it (sometimes the update causes this) then power the 4040 on and once it finished loading to the blue screen, using a paper clip, depress the reset switch on the left side and let it restart (little pinhole on the left side under the usb port)
if you need further help, just reply to this post.
bill
Jan 03, 2010 | Magellan Maestro 4040 GPS Receiver
How can i update my magellan maestro 3210 without usb cable
i would go www.magellangps.com and download them from the website directly to your computer. Then your gps should have a memory card reader of some sort. You can take your memory card and the updates you downloaded and then you load the updates from the memory card. .
Dec 05, 2009 | Magellan Maestro 3210 GPS Receiver
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 4250 blue screen, not able to reset
May 31, 2009 | Magellan Maestro 4040 GPS Receiver
After several munutes of on the screen goes to
I have a Garmin Street Pilot c330 which when plugged in and power button pushed, the screen lights up for a few seconds and shuts down. It was giving a low battery warning before shutting down. Where is teh battery in teh unity? and should I replace the fuse?
Apr 22, 2009 | Magellan Maestro 4040 GPS Receiver
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 3200 GPS Logo
104 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
