Maytag Bravos MTW6600T Top Load Washer Logo
Posted on May 18, 2011
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
Richard Simpson
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on May 18, 2011
Richard Simpson
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
4059
Points
54
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
Washer filles with water then buzzes
hi Timothy.
MOST PROBABLE REASONS FOR A BUZZING SOUND IN WASHING MACHINE:
  1. Blocked Drain Pump: An object has lodged itself inside of the drain pump. There can be items such as a small sock, a coin, a toothpick, or something small in your clothes pockets when you wash them. These items can fall out of the pockets and end up in the drain pump causing it to become blocked and make the buzzing noise you hear. Here is an audio recording of a blocked drain pump. Unfortunately, the only way to fix this problem is to take the washing machine apart and open up the pump and remove the object causing the buzz sound. To find directions to take your specific washing machine apart, do a Google search for Make and Model of your washer.
  2. Motor Coupling Broken: The motor coupling has broke and the motor turns but nothing happens. This will also cause a buzzing noise which can also be described as a vibrating noise. To fix this issue you will need to take the washer apart. Here is a video to show you what to look for if your washer motor coupler is broken. Once you know that the motor coupling is broken and needs replaced, we recommend ordering the part online. Simply do a search for "washing machine model motor coupler" and you will find the part needed for your specific washing machine.
  3. Washer Drive Block Loose or Worn: The washer drive block is not tight or has worn out. The part will need to be replaced to fix this problem. Here is an audio clip of a worn washer drive block to help you to diagnose that this is your actual issue. To further assist you with this issue, here is a video to show you how to replace a washer drive block.
  4. Worn Agitator Dogs: When these are worn, you will hear a clicking or crunching noise. These small plastic parts are used to turn the top of the agitator in one direction. This pushes the clothes down to the bottom part of the agitator to be washed. Here is what your washing machine will sound like when the agitator dog ears are worn. To replace these, order them online (about $5 bucks) and then install them in your washer. Here is a video to show you how to remove and replace washing machine agitator dogs.
  5. Washer Motor Burned Out: This may result in a buzzing noise depending on circumstances. The way to tell a bad motor is a distinct burning smell. This usually means your washing machine is old and the motor has died from old age. You may need to start thinking about buying a new washing machine. if that is not possible, you can buy a new washer motor for around $100 and install it yourself. Here is video showing how to remove a washing machine motor.
or try this.
Drain hose: If the washing machine is functioning correctly but makes a hummingsound while draining, there could be a problem with the drain hose. ... Then unplug thewashing machine and turn off the taps supplying water to it. Unscrew the fill hoses from the water valve.3 Nov 2014
Why Is My Washing Machine Humming? - Surewise.com
https://www.surewise.com/appliance.../8-reasons-why-your-washing-machine-is-hummi...
Based on your details, I would first check the drain pump to see if it's locked up due to a piece of clothing stuck inside the pump. You can remove the pump from the motor leaving the two hoses attached and then see if the motor will start. If it continues to just hum instead of starting, then it may be losing the start voltage. The motor needs start voltage and run voltage in order to start. The motor will just hum if it's not getting the start voltage.  The start voltage circuit is usually the red and yellow wires. Check the yellow and red wires at the motor, capacitor and at the timer for a loose connection. Make sure the red and yellow wires are pushed in all the way at the timer terminal quick disconnect plug. 120 volts should be present when measuring across the red and yellow wires. Check the white wire with the black stripe too at the timer and motor.
Washer filles with water then buzzes Google Search
Over filling washing machine. If you turn off power water still fills. Did another wash and it was ok but it has started over filling again. Also a slight buzzing noise fm washer
This sounds like the water mixer valve needs to be replaced.
Its the part the fill hoses screw onto at the back of the washer
Unscrew the fill hoses at the back and run water in washer to verify the
water is there.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
2answers
Washing Machine stopped through cycle and now will not turn on
I can help with this. I work on the units they make. If you can email me @ [email protected] I will guide you through
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
