Question about Amzer Silicone Skin Jelly Case for HTC Hero (Lilly )
It stop charging and can't be open
Dustbuster batteries won't hold a charge.
The AC is not full sine wave. The diode is in the wall adapter
Jan 15, 2013 | Computers & Internet
ASUS K54C won't power from battery
Take it back to shop if it's only 2 weeks old
May 06, 2017 | ASUS Computers & Internet
I cant open
Push the power switch up as far as it will go and see if the blue ring on the front of the player lights up.
The Fuze's power button is not a traditional button but a slider, so if you did not push the slider up all the way, this may be the only reason it was not powering on.
Reset the Fuze by pushing up on the power switch and holding it in the up position for 10 seconds.
Try to power on the Fuze again after it has fully rebooted.
Connect the Fuze's USB cord from the Fuze to a USB port on your computer.
You should see a yellow charging light illuminate and the battery symbol blinking on the Fuze's main display.
Once the battery stops flashing, the Fuze is fully charged and you can try to power it on again.
hope this helps
Sep 27, 2012 | SanDisk Sansa Fuze MP3 Player
Phone won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 28, 2012 | Pantech Pursuit Cell Phone
Macbook adapter A1184 stopped charging
Things break. Get a replacement on ebay. eBayeBay
Jul 28, 2012 | Apple MacBook Pro Notebook
I have nokia e7 I want to know is there any way to stop phone getting charged when we connect phone to laptop via its data cable
No but you shouldn't worry about it. It doesn't damage the battery and it'll stop charging when full.
Sep 18, 2011 | Nokia E7 (16 GB) Smartphone
My Canon ZR950 stopped working all of a sudden. Won't power on with battery (charged externally) or AC power cord. Tape holder doesn't even pop up and open. It won't do ANYTHING. It was...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Jul 16, 2011 | Canon VIXIA HV30 DV Camcorder
Amzer Silicone Skin Jelly Case for HTC Hero (Lilly ) Logo
Top Amzer Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an Amzer Cell Phone Expert? Answer questions, earn points and help others
