Question about Toys
Need owner's Manual for Craftsman wet/dry vacuum where I can find it?
  • 3,018 Answers
Regards, Tony
Posted on May 18, 2011
Do I need to remove my filter from my wet and dry vacuum to **** up water?
The filter is for dry pick-up only. Remove it for wet pick-up.
Aug 26, 2013 | Craftsman 17026 Wet/Dry Vacuum
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
Craftsman 179220 Canister Wet/Dry Vacuum
Maybe open the motor casing and look for an overheat reset button. If it doesn't have one, check for voltage at the wires coming directly out of the motor. If it has power there and no reset switch, then the motor needs replaced or rebuilt.
Jul 18, 2012 | Vacuums
Looking for owners manual do I need to take off the filter to vac fluids
Go to the Craftsman website, they have free manuals you can download. type in the model or serial number
Jul 29, 2011 | Craftsman 17026 Wet/Dry Vacuum
Craftsman wet dry vac no longer sucking enough to use, cleaned the filter, sounds strong but barely works??
Buy a new filter. Make sure hose is cleaned out. Sometimes if the filter is wet and not allowed to dry it will do that. Also make sure hose is on the right outlet
Dec 30, 2010 | Craftsman 17762 Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Do I take the filter off when I am vacuuming up wet things?
If it's a paper filter, take it off. If it's a cloth filter that can be washed and dried, leave it on. Your machine will have a float to close off the suction when the tub needs emptying. Anyway, air from the tub only goes through the turbine, not through the motor itself, so you need not worry. It's good practice to run the vac dry for a few minutes after using it wet, just to make sure the turbine's dry.
Aug 15, 2009 | Craftsman 17026 Wet/Dry Vacuum
I do not have my users manual and have never vacuumed wet with this vacuum. How do I change it from a dry to wet vacuum. Can't find my manual and I need to use the shop vac for water in basement, do I...
no - simply remove the filter. That is the only step necessary!!
Hope your cleanup goes well!!
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Craftsman 17761 Wet/Dry Vacuum
Need replacement manual
Go to Sears.com, click on the parts link, put in your model number, a parts list will come up, if you manual is available, you can click on it to buy it.
Jan 01, 2008 | Craftsman 17740 Wet/Dry Vacuum
Toys Logo
155 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
