Question about Maytag Neptune MDE5500AY Electric Dryer
How do you get the top off to tighten the screws on the blades? that are in the dryer
  • Maytag Master
  • 7,482 Answers
Hi zazaandbear...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and then the two screws that hold the filter housing.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Remove the drum and then you can tighten your screws that hold the blades in place.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on May 18, 2011
3 Suggested Answers
  • 291 Answers
SOURCE: My Maytag dryer has a loose dryer drum baffle.
unplug Dryer, open door, Remove two door hinge screws going into front panel, remove two screws on opposite side. Grab front panel on upper sides and twist and pull front panel out. Panel sits on two clips at bottom so you have to tip panel out to unhook from the bottom. You will see a metal hook with two screws in it that holds down the top of the dryer on each side. Remove the screws and hook bracket. Make sure you note how it reinstalls. Top will now lift up and lean back against a wall. It is hinged in back. You can now easily get to the drum baffle screws. Good Luck, Appliance Specialists
Posted on Dec 17, 2009
Testimonial: "I will try that quite soon. Thanks."
  • 1531 Answers
SOURCE: One of the tumbler blades is loose. How can I
There are two clips that hold the lid down. they are located about one inch in from either side of the machine you can use a flat tip screwdriver and push them in and the lid will come up giving you access to the drum vein screws.
Posted on Dec 02, 2010
Fan has begun to "hum"/squeek" when turned on and keeps me awake at night. I can't find a point to lubricate it. Home and fan are only 2.5 yrs old. Thanks for helpful tips.
Sounds silly, but tighten the fan blades - the blade is fastened to the metal at the top of the blade by two or three screws or bolts.
Apr 01, 2017 | Dryers
The blade inside my Maytag Atlantis dryer is loose. How do I fix it?
if it has the sloped front and door at the top front,then open door and remove 4 screws 2 on each side remove door then there are 2 screws under front of top cover remove these, then pull outward on door from edged of front cover to remove, then lift up top cover,then you can tighten or remove and replace paddles
Mar 11, 2012 | Maytag Dryers
Hi, I have a Craftsman C935 35516-3 corded lawn mower (about 15 years old). The blade is loose and I can not tighten it (the blade bolt turns without tightening . If I could remove the cowling, then I...
There are two philips screws on top. I got them with a screw extractor as they were rusted. You won't be able to fasten the blade from the motor side though.
Jun 05, 2011 | Garden
Maytag dryer blade inside of the drum
Is blade loose or broken off? Either way, you must remove front panel (door panel) to expose the front drum end retainer brackets, which you must unscrew and remove to get at screws to tighten or replace missing paddle blade. You can get replacement part at www.repairclinic.com their very reasonable
Feb 13, 2011 | Maytag PYE2300AY Electric Dryer
One of the tumbler blades is loose. How can I tighten the screws? I can see there are two screws holding the blade to the drum. What is the best way to get to the screws so I can tighten them? thanks
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I access the drum to tighten the dryer fins
Disconnect power to the dryer !!! Remove the 2 screws holding the door hinges on and remove the 2 screws opposite the door hinges . This will let you pull the top of the front panel outward and lift off the bottom clips . If you have enough room , slide your arm thru the front opening to tighten the screws . Otherwise , remove the 2 screws holding the clips for the top , 1 on each side , and lift the top , to get better access to the screws .
Apr 10, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Neptune Dryer Blades
Yes - right where the front panel meets the top panel of the dryer on both sides there are two clips. Insert a screwdriver into the clips and push up on top panel. You'll see the screws that hold the fins on the dryer. Tighten these screws or replace. Good luck...
Nov 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a Kenmore gas Dryer (stile #2) with the door that opens in the front. Inside the dryer, there are three blades (parts) that help the cloths turn. One is comming off and I noticed that the blade is...
you can take the top off there are screws in the back and clips on the front if you push on the clips with a flat screw driver lift the front edge and push the clip the top will tip up when you free the clips
Oct 20, 2009 | Kenmore 73952 Gas Dryer
One of the three things that tumble the laundry in the dryer is loose--it is making alot of noise--how do I tighten it
I think you are talking about the large ribs that prevent clothes from just sliding in the drum.
They are available as a spare, so are usually screwed in from outside the drum.
To fix your problem, turn off and unplug dryer.
Remove back pannel screws holding the lid on, and slide back the lid.
Rotate the drum by hand internally untill the faulty blade is at the top. You should be able to see the screws that need tightening.
Replace parts when finished.
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the 3 arm or flip in dryer is very loose
Remove the top of the dryer by removing the four screws in the back. the entire top should slide forward an inch allow you to lift and pivot the top off to the side. it will not come off entirely because of electrical wires. with that moved off to the side you should see the top of the drum. reach in the front door of the dryer and rotate the drum so that the loose blade is at the top. in that position you should be able to tighten the screws.
Jun 26, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
