Getting an error code #801 when sending a document to our f&p server
  • 61 Answers
SOURCE: hello i have two IR1024i error code #801
Have you entered dns server address and reboot, make sure password is correct
Posted on Oct 21, 2009
Canon error code 801
E602-0003 try to recover you program turn OFF the machine when turn ON just hold 19 when the small box show just wait in few minutes until the screen tuning full white.... if the code is the same just contact SC near by you to reprogram machine
Mar 06, 2012 | Canon (6981A002AA) for imagerunner 2200,...
I can't sign in Y!M clicked troubleshooting and I got this Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the...
Bruno
Start your troubleshooting with a clean browser
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_cclean...
On the sign-in page click Messenger > Connection Preferences - make sure there is nothing untoward in the lower 2 boxes - if incorrect make changes using the drop-box options > OK
Copy this Yahoo secure site URL
https://www.yahoo.com/
Open Yahoo Messenger > Tools > Internet Options > Connection tab > LAN settings > Uncheck everything then check 'Automatically detect settings' and 'Use a proxy server' > Advanced > Paste the address in the secure box and type 5050 in the port box > OK
Sign in.
Hope this helps.
Mar 12, 2011 | Yahoo Messenger
Cannot get license, because server send error code:47-ncomputing
Cannot get license, because server send error...47
what is solustion this prbloems
Jan 31, 2011 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Where can I get a Light Engine for Sony KDF-60WF655 TV . My TV has BLUE in the right corner and is extending to the middle of the TV.
!!!IMPORTANT!!!
YOU MUST SEND ME YOUR LIGHT ENGINE AND I WILL REPAIR
CALL
801-920-7165
!!!IMPORTANT!!!
CALL
801-920-7165
ROBERTYOUR SONY LIGHT ENGINE WILL BE REFURBISHED WITH SONY ORIGINAL PARTS. THIS LIGHT ENGINE WILL LAST FOR MANY YEARS THE DEFECTIVE PART WILL BE REMOVED AND REPLACED WITH SONY ORIGINAL PARTS! SIMPLY SEND YOUR SONY LIGHT ENGINE TO ROBERT MILLAR 1426 23RD STREET OGDEN, UTAH 84401
THE DOCUMENTS BELOW WILL BE SENT STANDARD POST FOR YOUR RECORDS WARRANTY SIGNED IN INC BY ME ALSO A PROOF OF PURCHASE INVOICE.
Certificate of 6 MONTH WARRANTY
Item: Sony LCD Light engine
Customer Name_________________________
Warrantor Name__________________________
Robert Millar 1426 23rd street Ogden, UT 84401
Phone 801-920-7165
I warranty the Sony LCD panel with MY STAMP AND THE DATE OF INSTALLATION for the time period of 6 months
My signature________________________________
Estimated Date of installation_________________
THE DOCUMENT BELOW WILL BE EMAILED SAME DAY AS PURCHASE
PLEASE PLACE THIS DOCUMENT WITH YOUR SONY LIGHT ENGINE THAT YOU SEND TO ME
Certificateof Refurbishment, 06 MONTH WARRANTY
Please print your name_________________________
Please print your Email__________________________
Light Engine Serial Number _______________________
Calibration Description:
The optical block has three LCD panels red, green; blue the convergence is adjusted to a tolerance of 92%
Convergence formula;
Convergence = (The area of diverged grid @ 720p) /(Total area for converged red, green, blue gridline @ 720p) ? (100).
Technician name: ___________________________
Technician signature: ________________________
Date of calibration: ______________
Phone 801-920-7165
VISIT YOURSONYREFURB.COM
Jul 24, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hello i have two IR1024i error code #801
Oct 21, 2009 | Canon Office Equipment & Supplies
I have a Canon ir 3045 copier, when I try to send the scanned copy directly to a file, the file doesnot save to the destination network folder. When I looked at the scanner send logs i saw status as NG...
I have a Canon ir 3045 copier. I had sucessfully scanned two documents but the third scanned document (107 pages) was not emailed to me. When I click on press details, the job type reads #801. how do i retrieve the document?
Apr 24, 2009 | Office Equipment & Supplies
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Life style error codes 801 & 802
Hi, I had the same problem, they had to replace my harddrive and the dvd, lost all my music, 145 cds, just got it back, it now works fine,
good luck
jps
Dec 31, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
985 people viewed this question
k24674
