Question about GE DPSB613EDWW Electric Dryer
How do I change the belt on my GE profile model DPSB613EDCC dryer
  • GE Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on May 18, 2011
How come when i changed the belt there is so much play on the new belt im not sure if i have the idler tensioner on right ?
That could be the problem look at how the belt is running thru the tensioner and the shaft of the motor. Then run the belt the opposite way if still the same you might have the wrong belt. Get the model number off the dryer and take new belt back to parts house with model number to make sure its right hope this helps.
Jan 07, 2011 | GE Profile Prodigy DPSR513GA Dryer
Where is the heating element located on the GE DPSB613EDWW / DPSB613EDCC Electric Dryer ?
the heating Element is located behind the drum...In order to acces you would need to remove the complete drum from the front of dryer..
Apr 20, 2010 | GE DPSB613EDWW Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
GE dryer model DDSR475ET0WW, need dryer belt
Follow this link for your part:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=207614
I got parts from these guys really fast. Repair went very well.
Jan 25, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Dec 11, 2008 | GE Profile Wizard DPSE592EAWW Electric...
GE Profile Dryer (Not a Harmony)
Procedure is much the same, just easier. Don't take belt off. Pull drum straight forward six inches or so and replace the hat shaped teflon drum bearing.
Sep 28, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DPSB613EDWW Electric Dryer Logo
137 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
