Question about KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher fills but does not wash. Dishwasher will drain if program cancelled.
    Problem Solver:
  • 23 Answers
Do you hear a humming sound, like the motor trying to run, then stopping for a minute or two before trying again?
Usually, dishwashers run the motor one direction to wash, and the opposite direction to drain, but some use a valve to switch. If you see wires going to a bulky flapper looking part sticking off the side of the pump/motor, you might have a bad valve actuator.
Otherwise, you might have a motor refusing to turn in one direction. You can usually access the shaft from inside the tub by removing the washer arm to get access to the pump impeller. Do not remove the impeller unless necessary, but see if it will turn both directions. Broken glass or pieces of bones or other debris might be interfering with the rotation. If it turns freely both ways, but still won't wash, it is likely you have a bad starter coil on the motor, and will need to replace the motor/pump assembly. These usually have a longer warranty than the rest of the unit, so if yours is less than 5 years old or so, it would be worth checking with factory service.
Posted on May 18, 2011
How can i set program time when power failure during dishwasher is running ?
There should be a "cancel and drain" or similar to drain the machine and so you can restart your choice of wash cycle when power comes back on again. I don't believe it's possible to have the machine resume from where it was in the wash program if the power fails.
Sep 26, 2015 | Samsung Dishwashers
Dishwasher fills up with water put wont go into wash cycle and wont drain
your drain hose is probably plugged to the drain especially if it goes through the garbage disposal first,remove drain hose from dishwasher at the disposer and see if its plugged,if so unplug obstruction,then start it and put hose in sink and press drain/cancel and see if it drains now
May 12, 2012 | Hotpoint Dishwashers
It will start and fill with water, but doesn't
1)check door safety switch. 2)check wash pump working.
Jun 03, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I just replaced the drain pump in my bosch shu3307uc dishwasher.When I turned it on it filled with water and then I put it in the drain mode' It drained but it would not allow me to advance to start the...
You have to allow the drain cycle to finish completely, or find cancel drain dot points and press both at the same time, to reset program, open the door and close it to make sure the micro-switch activate properly
Jan 06, 2010 | Dishwashers
Dishwasher won't always fill with water
if the unit fill the first time you start it after it fill and starts to wash hit cancel let it drain if it fails to fill again 2nd or 3rd time you have a bad fill valve
Aug 20, 2009 | GE Dishwashers
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
LE light on...not filling with water.
ACCORDING TO SERVICE MANUAL, THE "L.E." ERROR CODE SUGGESTS A LOCKED ROTOR ON THE WASH MOTOR. CHECK THE WASH IMPELLER FOR A FOREIGN OBJECT. IF IT SPINS FREELY, CHECK THE WIRING TO THE WASH MOTOR FOR LOOSE CONNECTION.
THE L.G.HAS HAD A HISTORY OF MOTOR PROBLEMS.
YOU SHOULD BE ABLE TO CANCEL THE PROGRAM AND DRAIN OUT THE WATER.
Apr 03, 2008 | LG 24 in. LDF 7811 Stainless Steel...
KitchenAid KUDK03ITBK Built-in Dishwasher Logo
341 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
